first day home..
I bought some mc18 barrels, pistons, carbs etc to replace the shagged mc16 items, found some tyres and got it to the mot station..
After bribing the tester it got a valid mot, so went for a run.
Fairly impressed, lots of room for improvement though! New brakes for starters so I bought a set of armstrong sintered pads and fitted them. Once they had bedded into the grooved disks the braking was a lot better and I started having fun on it.
Lovely....
After a scare with the old tyres I'd fitted I bought some bt45's and they did the handling a world of good! I also fitted some tyga cans to the standard pipes which freed the engine up somewhat!
I then fitted a cbr929 rear shock, which made the back end pretty bloody good to be honest, I fiddled with the front and got that somehwere near useable so she was not handling as well as stopping and going!
I had a trackday booked, that I was planning on using the rgv for, but due to not getting the heads back in time I had to use the little nsr for this task. I had worries about using it as its a pretty unknown quantity as to the crank life but what the hell.. if it went bang I'd use the nc30!
Well.. what a suprise, it went very well on track, struggling for power up the back straight at anglesey but where the diesels were passing me on the straight I was flying past them on the brakes! Even with bt45's the bike was really behaving well, inspiring lots of confidence!
Well that was it.. I was sure I could make it into a decent forgotten era racer for next year, maybe not fast enough to pass the leading reverse cylinder tz's but could certainly give them some hassle!
So I start getting a few ideas together, first thing is to bin the standard pipes. martin77 kindly made me a set for it, in kit form to save travelling down south to have them fitted..
But no fit with the standard swingarm so a '21 item was sourced (cheers ricey3) and I started fitting it the other day...
CBR929 shock
But the ride height is mental now due to the swingarm-linkage bracket being too high
Bum, but I'm sure I'll get round it somehow!
I'll post updates as and when I get the chance to work on it.. hoping for 65hp but a nice strong midrange!
Paul
