headlight globe
biatchy
headlight globe
Fri Oct 14, 2005 2:10 pm » Post: #1 » Download Post
i bought a new globe for the headlights today..
but it doesnt fit...it has 3 bits coming out around the edges, but they just dont line up with the gaps to go in place...it looks like the previous owner snapped one of the pieces off to make it fit....
is there a specific globe i need?
cheers
Philip Ahn
MC21 NSR250R
im poor...
biatchy
Fri Oct 14, 2005 2:32 pm » Post: #2 » Download Post
i made it fit.
i ahve put the lever thing over it which holds it in place, connected the glode up and plugged in the grounding(the one coming out from the centre of the headlight unit) plug also. hi beam works fine....but low beam doesnt work.
i have cheked all the fuses underneath the seat and they are ok..
any ideas.
cheers
Philip Ahn
MC21 NSR250R
im poor...
Fri Oct 14, 2005 3:01 pm » Post: #3 » Download Post
I presume a "globe" is a bulb?
Anyway I'm not sure about Aus but in the UK the bulb size required for NSR's is very similar to a size called H4 thats used by lots of cars. Plenty of people just use these instead and bend/cut the pins to "fit"
The problem is that Jap homemarket bikes expect 35w on low beam and these H4 bulbs are 55w, hence regulator rectifiers die and (on the grey Honda 400's for definate) the main beam light switch melts as the power is passed through the switch itself not a relay (which was fitted to UK VFR400s as standard).
Dave Silver Spares sell the real Honda 35w/60w bulbs in the UK for £5 each (genuine spares, RVF400).
Can't help for Aus sorry.
biatchy
Fri Oct 14, 2005 3:20 pm » Post: #4 » Download Post
hmm...
yeha i have bought a H4 globe and installed it. 12V 60/55W.
i just bought this one as i assumed the previous bulb in there was the correct one..guess not.. Sad
so the regulator rectifier is dead? shite...
what do i need to do? is it costly to fix?
thanks.
Philip Ahn
MC21 NSR250R
im poor...
biatchy
Fri Oct 14, 2005 3:54 pm » Post: #5 » Download Post
i want to add...
i have given the bike a few rides in the last few days...not too long maybe about 5 kms or so...revs great in all gear etc...
starts easy next time i kickstart it...
so i dunno...the regulator/rectifier seems ok.....?
Philip Ahn
MC21 NSR250R
im poor...
Fri Oct 14, 2005 6:43 pm » Post: #6 » Download Post
No, it may be fine, for ages, or forever. Or the reg/rec may have been replaced with a new (better) one.
250's don't seem to have that many problems with electrics, the NC23/29/30/35 are renound for it, it's about the only thing that goes wrong with them. It's just something to be aware of, my '28 has been "wrong" since I got it, so was my NC35.
Obviously it (the reg/rec) can handle a 55w drain from the lights, it can handle a 60w from the main and a 95w from a mainbeam flash (35+60 note:- when you flash the main lights up as well, unlike when you switch) so it must be able to, wheather it can handle it all the time or can handle the 115w draw from a flash on an H4 bulb is another matter. Also the 400's run twin headlights so the "problem" is doubled, this is probably why NSRs don't fry the mainbeam switch yet both of my RVF's and my CBR4 all did.
biatchy
Fri Oct 14, 2005 6:56 pm » Post: #7 » Download Post
ok...cool...
then if my low beam switch is "fried"....
where should i look? what will i need to do..
thanks for all the help
Philip Ahn
MC21 NSR250R
im poor...
Fri Oct 14, 2005 8:38 pm » Post: #8 » Download Post
Thinking about it I don't think the will NSR's do it, 1/2 the power, same switch, see? What happens is one day you press main beam on and when you change back the button has got that hot that it's melted a bit, the low beam circuit doesn't connect anymore and it all goes black, so you hit mainbeam again, ride home blinding everyone and take the switch to bits and clean it up.
Jeff SZ
Fri Oct 14, 2005 11:12 pm » Post: #9 » Download Post
I think in the USA a Honda VFR uses a different bulb then standard H4, were the pins are located different. They may fit a NSR ?
Jeff SZ
Fri Oct 14, 2005 11:12 pm » Post: #10 » Download Post
biatchy
Fri Oct 14, 2005 11:53 pm » Post: #11 » Download Post
so i should firstly dissasseble the switch unit un the left handlebar and see if stuff is melted then right?
and so i need 12V 60/35W bulbs?
cheers
Philip Ahn
MC21 NSR250R
im poor...
biatchy
Sat Oct 15, 2005 12:49 am » Post: #12 » Download Post
i had a look inside the switch unit and all seems ok...everyhting is connected/soldered. there does seem to be a li bit of melted black stuff but i cleaned it and all looks good.
by the way...when i use the switch to turn the low beam on, the instruments still light up fine, so the actual switch is ok?
Philip Ahn
MC21 NSR250R
im poor...
biatchy
Sun Oct 16, 2005 1:45 pm » Post: #13 » Download Post
anyone got any ideas?
Philip Ahn
MC21 NSR250R
im poor...
Mon Oct 17, 2005 8:07 am » Post: #14 » Download Post
Stick a voltmeter into the bulb connector, and see if there's 12v there. Shuld be on one connector at high beam, and the other at low beam. The third connector is the earth.
biatchy
Mon Oct 17, 2005 9:15 am » Post: #15 » Download Post
so i should put one into the earth and one into the low beam hole correct?
_______|___|
_________|
which would be the earth, low, hi beam etc?
Philip Ahn
MC21 NSR250R
im poor...
