NSR250 MC18 R5K Engine Rebuild
philup_7@hotmail.com
Mon Mar 09, 2026 3:08 pm » Post: #1 » Download Post
Hi All
It has been a fair while since I last wrote on the Forum due to various reasons (getting older is top of the list lol), but also been fairly busy sorting & rebuilding my son Chris’s NSR250 MC18 R5K with him.
But, before I start, can I thank all those on the NSR WORLD Forum (you all know who you are) for all their help & pointing me and Chris in the right direction as none of the following would have been possible, not forgetting all the invaluable information on the NSR WORLD site itself.
Our first attempt was to fit a used MC28 Engine to the MC18 which looked in reasonable enough condition to do. However, fitting the MC28 Engine into the MC18 threw up a number of issues, and items to be purchased, that although have been previously documented I guess it’s not till you try & do it you just don’t realise!
The issues & items required as follows:
    (1) New/Used MC21 PROTEC GPS-01 Gear Position Sensor Product 11609 or MC28 Change Switch (MC18 Neutral Switch is not only completely different, it is also in a different position on the Crankcase to the MC21/28 & operates in a totally different way. Additionally, Neutral switch re-wiring is required, but this is not much of an issue.
    (2) Used MC28 2T Oil Pump as one didn’t come with the Engine (MC28 2T Oil Pump has an additional Oil Way to the MC18);
    (3) New DMR-JAPAN Dry Clutch Collars/Spacers (Original Spacers had worn so bad the Clutch didn’t work at all);
    (4) New DMR-JAPAN MC28 Water Pump, TYGA & DOGFIGHT RACING also supply their own one as well (The issue with the Water Pump arose when sorting the Clutch issue above out);
    (5) New DMR-JAPAN Wide RC Valve Pulley Type2 with a wide Pulley & over-torque release mechanism (Our attempt to get the MC28 RC Valves to mate as best as you can with the MC18’s PGM II).
NOTE: More detail of these issues above will be dealt with as I continue to add to this topic in the coming weeks.
Most of the parts above were obtained via: WEBIKE JAPAN, AMAZON JAPAN, JAUCE JAPAN & Jap4 UK Ltd.
After riding the NSR250 for a little while, the MC28 Engine decided to be near impossible to start, so a re-think led to a total rebuild of an Engine for the MC18 R5K as follows.
Rebuilding the MC18 consisted of using the MC28 Crankcase, new or rebuilt MC28 Crankshaft (Steve at Performance Engineering, Plymouth) with the MC18’s Cylinders (Nikasil plating by Langcourt, Weston-Super-Mare, UK), original Cylinder Heads, Stator & Pick-ups.
Detailed instructions on the complete Engine strip and rebuild are on the NSR WORLD site which I found extremely useful and as you will see a great deal of similarity. The MC28 Engine was removed for cleaning prior to dismantling & all parts open to any ingress were taped off and sealed.
Last edited by philup_7@hotmail.com on Mon Mar 09, 2026 4:48 pm; edited 3 times in total
Mon Mar 09, 2026 3:12 pm » Post: #2 » Download Post
MC28 2T Oil Pump
Although the MC28 2T Oil Pump was removed prior to the Engine removal, I’ve included a Picture detailing the additional Oil Way that isn't present on the MC18.
Last edited by philup_7@hotmail.com on Mon Mar 09, 2026 8:22 pm; edited 2 times in total
Mon Mar 09, 2026 3:46 pm » Post: #3 » Download Post
Dry Clutch Removal
Remove of the outer Dry Clutch Cover to reveal the Dry Clutch Pressure Plate.
Undo (in a crisscross pattern 2-3 steps) & remove the 5 Bolts, 5 Clutch Pressure Plate Springs & Pressure Plate to reveal the Lock Nut.
Remove the Clutch Lifter piece (in the centre) & unstake the Lock Nut with a small Screwdriver lightly tapping it with a Hammer, then undo the Lock Nut using an appropriately sized impact Socket & Cordless Impact Driver (the Lock Nut came off fairly easily, which is unusual for me).
The Lock Nut, Thrust Washer, Clutch Plates & Clutch Inner Basket/Drum can now be removed.
Undo the 6 Bolts holding the Clutch Outer Basket & remove the Basket.
Last edited by philup_7@hotmail.com on Mon Mar 09, 2026 8:25 pm; edited 3 times in total
Mon Mar 09, 2026 3:53 pm » Post: #4 » Download Post
Dry Clutch Housing Removal
Righthand Crankcase Cover Bolts removed revealing the new DMR-JAPAN Water Pump from WEBIKE JAPAN previously installed due to the old Plastic drive gear cracking (not surprising given its age, bit like me really).
The MC28 Water Pump differs to the MC18/21 regarding the number of teeth on its drive gear, MC28 has 25 teeth and the MC18/21 has 26 teeth so made sure I got the correct pump. The one I chose was Product E4-28005 from WEBIKE JAPAN as it came with the Seals & Gaskets, although it is also available as separates’.
General Components under the Dry Clutch Housing Cover.
Last edited by philup_7@hotmail.com on Mon Mar 09, 2026 8:24 pm; edited 2 times in total
Mon Mar 09, 2026 4:04 pm » Post: #5 » Download Post
Flywheel Removal
Using a Flywheel Puller tool (TYGA TYTO-0014), 19mm Ring Spanner & Adjustable Spanner the next job was to remove the Flywheel Bolt & Flywheel, which to my surprise came off very easily (have had very bad experiences with Flywheels in the past mostly to do with cars though lol!).
ericandchi
Mon Mar 09, 2026 10:08 pm » Post: #6 » Download Post
Great pics and annotations. This will be very helpful to others in the future.
