Exhaust dilemma.
PGM4
Exhaust dilemma.
Sun Aug 11, 2013 8:04 am » Post: #1 » Download Post
Finally got round to fitting some Nikkons to the '21, now the fairings are touching both sides in the area of the forward lower vent. Do I 1/ dent the chambers and/ or hack my new fairings around, or 2/ send the fookers back? How detremental would the dents be etc
MC21 money pit Crying or Very sad SV650N Cool Honda SS50 Very Happy
Sun Aug 11, 2013 9:19 am » Post: #2 » Download Post
All the Nikkons I've seen are very fat and based on (I think) the JHA pipe. We've almost always managed to space the fairings out to allow them to fit.
Sun Aug 11, 2013 3:11 pm » Post: #3 » Download Post
Very few aftermarket chambers fit within the confines of the OEM bodywork.
TYGA were the only company I know of that supplied any fitting instructions for their chambers, but it doesn't appear they are on their site any longer. There is however this statement:
"Do I need to cut the fairing to make my TYGA pipes fit?"
"No, unlike some other systems, this should not be necessary. We endeavour to make all TYGA products compatible with otherwise stock bikes. On the MC21, you may need to reposition the lower right side position of the fairing slightly. Remember to loosen off all brackets and fasteners and adjust bodywork. Always make sure there is clearance around the pipe or it will burn the bodywork. Only a small clearance is necessary to stop heat conduction. "
This is relevant information to almost all aftermarket MC21 and MC28 chambers. The only ones I seem to recall that fit inside stock bodywork are DogFight and some Ethos systems.
As I recall, the Nikons are indeed some of the fattest pipes, but a Stephen says, you should still be able to space the fairing lowers out far enough to accommodate them. Whether it's worth the effort for Nikons however, is debatable!
stefanos-MC28
Sun Aug 11, 2013 10:33 pm » Post: #4 » Download Post
Also the JHA 500V chambers fit in the bodywork of an MC28 with no modifications.
But they were made for use with the racing JHA footpegs.
With the stock footpegs needs two spacers 10mm length behind the right footpeg bracket.
Owner of : Honda NSR250 MC28 95sp colours / Honda NSR250 MC18 R6K SP / Honda RS250 NF5 89 in boxes Sad / Honda C50 12V cub / Honda C50 12V super cub Japanese version /Yamaha XT600 89 benetton
Sun Aug 11, 2013 10:47 pm » Post: #5 » Download Post
I need a set of those pipes for my next project!
stefanos-MC28
Sun Aug 11, 2013 11:29 pm » Post: #6 » Download Post
http://aucview.aucfan.com/yahoo/h177569648/
PGM4
Mon Aug 12, 2013 6:54 am » Post: #7 » Download Post
THREAD HIJACK has anyone got something a bit more constructive to add, I haven't actually seen any bad reports about these pipes in general only good. If the sound is good I ain't really bothered about a 1/4 of a bhp deficit or whatever versus a £600 set of pipes that isn't available any more etc
Mon Aug 12, 2013 7:00 am » Post: #8 » Download Post
I would be denting the pipes before I cut the bodywork.
Good undamaged bodywork is near impossible to find these days and worth more than a pair of nikons!
Mon Aug 12, 2013 7:16 am » Post: #9 » Download Post
If you want everything to fit as OE then put the stock pipes back on.
As we have already pointed out, most aftermarket pipes will require some sort of modification if they are being used on an otherwise stock bike.
