power valves issues
mrkeung
power valves issues
Thu Jun 07, 2012 9:42 pm » Post: #1 » Download Post
hi
can i have some help with my mc21? i discovered my mc21 lost power starting at 7500rpm and struggled to spln past 9000. it also topped out at 130 km on a long straight at the track. i recently dropped both exhaust pipes, cleaned the power valves, checked the power valve motor as well. they all seem to be working fine.
i removed the airbox n checked the carbs today but the bike still run like very weak.
any suggestions and ideas
thank you
nxrsr20
Sat Jun 09, 2012 10:37 am » Post: #2 » Download Post
what condition is your air filter in? What about your battery? How fresh/stale is your fuel? How old are the plugs?
mrkeung
Sat Jun 09, 2012 8:41 pm » Post: #3 » Download Post
Hi,
Air filter is clean, battery is also new,fuel is good, and plugs are new but pretty dark after 2 trackdays.(bike ran poorly and had revving problem)
I started the bike today but it was having so much trouble to stay running and idle was rough.
Thank you again.
stefanos-MC28
Sun Jun 10, 2012 12:54 am » Post: #4 » Download Post
Hi
Check your ignition coils with a multimeter if they have the correct Ohm measures.I had a simillar problem with yours on my MC18 and it was the ignition coils.If you dont know how to do it take a look here at this thread http://nsr250.net/forums/viewtopic.php?t=11280&highlight=ignition+coils+check+cheque
It will helps also a lot if you have access at the service manual.
Good luck
