hi
can i have some help with my mc21? i discovered my mc21 lost power starting at 7500rpm and struggled to spln past 9000. it also topped out at 130 km on a long straight at the track. i recently dropped both exhaust pipes, cleaned the power valves, checked the power valve motor as well. they all seem to be working fine.
i removed the airbox n checked the carbs today but the bike still run like very weak.
Hi
Check your ignition coils with a multimeter if they have the correct Ohm measures.I had a simillar problem with yours on my MC18 and it was the ignition coils.If you dont know how to do it take a look here at this thread http://nsr250.net/forums/viewtopic.php?t=11280&highlight=ignition+coils+check+cheque
It will helps also a lot if you have access at the service manual.
Good luck
