NSR150SP Cylinder & Piston, Type A, B, C
HellRider
Thu Feb 17, 2005 3:17 pm » Post: #1 » Download Post
To all senior riders, recently due to some unforeseen circumstances, I had to change my Cylinder, Piston & Piston Ring. I went to my agents to enquire some details. To my findings in the parts catalog, I realised tat they have 3 types of cylinder & piston. It is as follows:
Cylinder A - Piston A
Cylinder B - Piston B
Cylinder C - Piston C
What's the difference between A, B, C?
Fri Feb 18, 2005 6:28 pm » Post: #2 » Download Post
They are all different sizes. You have to pick a piston that suits the barrel you got. The sizes shoudl be in the work shop manual.
HellRider
Sat Feb 19, 2005 8:38 am » Post: #3 » Download Post
Wat's barrel? Issit cylinder? Sorry, I'm new to this...
Does tat means that if I use Cylinder C & Piston C, my performance will be good?
jeff350lc
Sat Feb 19, 2005 9:26 am » Post: #4 » Download Post
yes barrel is the cylinder. and if you have a C cylinder, use the C piston.for the correct running clearance.
Sat Feb 19, 2005 5:02 pm » Post: #5 » Download Post
Please click image for larger view...
The 150 is unique in that an "A" cylinder uses an "A" piston and so forth, whereas with all the 250's, an "A" cylinder would use a "B" piston!
More info for the 250's cyliner/piston configuration can be found on the relevant pages of the Online Parts Manual.
HellRider
Sat Feb 19, 2005 8:48 pm » Post: #6 » Download Post
Yeah... this was the catalog which I saw too. Thanx Andy.
So, which will be better in performance wise & factory NSR150SP comes with which combination?
Mon Feb 21, 2005 6:04 am » Post: #7 » Download Post
If you use the recommended cylinder and piston combination then the performance between the three sizes available would be so small you couldn't measure it. if you have to buy a new cylinder and piston then order whichever is available.
From what I've seem, the B is the most common fitment to the stock machine.
HellRider
Mon Feb 21, 2005 5:41 pm » Post: #8 » Download Post
So Matt... U're suggesting me to get Cylinder B & No mark Piston?
Tue Feb 22, 2005 3:02 am » Post: #9 » Download Post
Might be the best plan
HellRider
Tue Feb 22, 2005 2:11 pm » Post: #10 » Download Post
Ok... thanx alot Matt. Laughing
