MC18 barrels and pistons fit MC16?
2Smoke
1987 Honda NSR250 MC16
Wed Jan 28, 2009 10:22 pm » Post: #1 » Download Post
Hi, was wondering if mc18 barrels and pistons fit an MC16? as I have seen some '18 items for sale but no joy with '16 pistons etc!
Thanks!
Paul
Wed Jan 28, 2009 10:23 pm » Post: #2 » Download Post
Yes they fit and are a good way to up power.
2Smoke
Wed Jan 28, 2009 10:26 pm » Post: #3 » Download Post
Spot on thanks, dont suppose you know what the physical differences are do you?
Thanks!
Paul
Wed Jan 28, 2009 10:30 pm » Post: #4 » Download Post
'18 has a bloody great exhaust port compaired to a '16 and power valves to match.
2Smoke
Wed Jan 28, 2009 10:33 pm » Post: #5 » Download Post
Ah I see, new to these nsr's really. Know about Lc's and tzr's and rgv's though Laughing
Is it worth getting carbs to match too? Any other worthy upgrades worth mentioning?
Thanks!
Paul
Wed Jan 28, 2009 10:36 pm » Post: #6 » Download Post
MC18 carbs are a good upgrade too. They are 32mm compaired to the 28mm on the MC16.
Once you've done that you're pretty much up there power wise if its got a good bottom end in it.
2Smoke
Wed Jan 28, 2009 10:43 pm » Post: #7 » Download Post
Sound, what sort of power gains should I expect to see with that combo?
Is it worth buying exhausts for it or do stock work best?
Thanks
Paul
Wed Jan 28, 2009 10:45 pm » Post: #8 » Download Post
An MC16 motor with '18 barrels/heads and carbs should make 58-60hp or around 2-4hp more than a RGV!
Stock '18 pipes are super. Never run a set of stock '16 pipes so couldn't say. I would guess '16 pipes will be fine tho.
2Smoke
Wed Jan 28, 2009 10:49 pm » Post: #9 » Download Post
Shocked Bugger, that much eh! I'm going to enjoy this nsr thing I think Very Happy
I can see the car/lc budget going down the pan for a few more months Cool
Thanks for the help!
Paul
Wed Jan 28, 2009 10:56 pm » Post: #10 » Download Post
To really get a '16 motor to go you need to get inside the cases. It's quite a bit of work though for around another 2hp.
'18 barrels, carbs and heads are the best and cheapest way to get good power from one.
2Smoke
Wed Jan 28, 2009 11:00 pm » Post: #11 » Download Post
Superb! How are they restricted as standard?
Wed Jan 28, 2009 11:01 pm » Post: #12 » Download Post
Really small exhaust ports! Laughing
2Smoke
Wed Jan 28, 2009 11:03 pm » Post: #13 » Download Post
ahh I see a pattern forming here Laughing I suppose '18 pistons are easier to get than '16 ones?
Wed Jan 28, 2009 11:11 pm » Post: #14 » Download Post
'18 ones are yes. Or you can use '21/'28 pistons but must use them as a pair as the skirt are a little shorter. Better to use '18 ones though.
I have turned down '18 pistons to run in '21 motors hav'nt I Andy. That went really well infact!
2Smoke
Wed Jan 28, 2009 11:12 pm » Post: #15 » Download Post
did it work? I have trimmed down pistons in the lathe before with no problems... was some time back mind Smile
