front magtek
beakergixer750cc
front magtek
Sun Jan 20, 2008 1:14 pm » Post: #1 » Download Post
I just got round to looking at my new front magtek and discovered that there are no threads in the holes for fixing disc Surprised I can't believe Honda forgot to thread them Shocked
Any thoughts on this anyone Idea
cheers Rob
Sun Jan 20, 2008 2:15 pm » Post: #2 » Download Post
Hopefully this is a joke, a Magtek uses a long bolt that passes right through the wheel.
maxim
Sun Jan 20, 2008 2:16 pm » Post: #3 » Download Post
Ahh it's not an oversight...!
you can't bolt into the mag alloy, so the disc bolts go all the way through the hub and pull the discs together into the wheel. You will need to get the corrects bolts and nuts from Honda.
Sun Jan 20, 2008 4:09 pm » Post: #4 » Download Post
Well, there goes my April 1st topic! ROTFLMAO
Sun Jan 20, 2008 10:19 pm » Post: #5 » Download Post
The disk bolts on my RS250 Magtek wheel bolt straight into the hub, but my NSR250 Magteks bolt through the hub.......not sure what to make of that? Apart from perhaps I have to many wheels Shocked
Sun Jan 20, 2008 10:22 pm » Post: #6 » Download Post
Having had a few minutes to think about it.......you can't possibly have too many wheels.
Chester362
Sun Jan 20, 2008 10:51 pm » Post: #7 » Download Post
I bought the correct bolts & nuts for the magtek wheels I`ve got.
Can`t see any reason why you couldn`t tap & fit helicoils to allow you to fit ordinary bolts to hold the discs on. The helicoil inserts are a lot harder wearing than the alloy of the wheels.
The part no.s for the correct nuts & bolts are on the parts manual on this site.
Mon Jan 21, 2008 12:13 am » Post: #8 » Download Post
I don't know why they did it like that either. Confused
maxim
Mon Jan 21, 2008 8:54 am » Post: #9 » Download Post
Because it's a road bike wheel, and it's safer!
Mon Jan 21, 2008 11:42 am » Post: #10 » Download Post
A proper RS magtek has its disks bolted directly onto the wheel. You have to be very carful with the threads though as they tend to feel like cheese. Like Maxim says the NSR magteks are almost idiot proof for this reason.
beakergixer750cc
Tue Jan 22, 2008 6:41 pm » Post: #11 » Download Post
THIS WAS NOT A TRICK QUESTION Smile never having had a front magtek before!
Thanks for your answers
cheers Rob
Tue Jan 22, 2008 8:44 pm » Post: #12 » Download Post
You arent the first halfwit to fall for this one Rob! I bought a new set of standard disc bolts for mine, I couldnt understand why one disc was held on with studs and nuts while the other was attached with normal bolts........ until I took it to bits!!! Embarassed Embarassed Embarassed
Tue Jan 22, 2008 8:48 pm » Post: #13 » Download Post
Mind you at least we can comfort ourselves with the fact we both picked up brand new front magteks for peanuts Very Happy !
By the way thanks for the tip off on that Wink
beakergixer750cc
Fri Jan 25, 2008 3:11 pm » Post: #14 » Download Post
I'm going to tap them for helicoils tomorrow at work,hopefully i wont bugger it up!
As you said Paul we did only buy them for peanuts Wink
cheers rob
Chester362
Fri Jan 25, 2008 6:35 pm » Post: #15 » Download Post
Smug bleeders! Evil or Very Mad
Seriously though, good luck to you both. Very Happy
