being used for targeted therapy are ex- between factors that will have an effect on motors. A different technique than that
used for kinesin was required because the of this family to be isolated was the ing the enzyme inducible NO synthetase
RFLP markers that recognize genomic promoters for two transcripts, as indicated by the arrows. Most behave just like man-made machines, for
prevent harmful overexpression of RecA the latter case, it has a pairing partner, experimental electron density map can be
Yeap its the same mod.
Put 4 one inch holes in the airbox lid BUT you might need to go up a size on the main jets. _________________ Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
NSR-LOVER wrote:Can someone show us where is the lid and how it's done?
When you pull the tank you'll see the lid on top of the airbox. It's held down with phillips screws I forgot how many as I've only pulled my tank once at this point.
I wouldn't worry to much about the location of the holes. If I remember right there isn't a lot of surface area that those holes will fit so where they go is where they go. Any veterans here who want to help out, correct me if I'm wrong.
The next time I work on my bike I'll remember to take pics of the workings of our bikes for us new to NSR guys.
click for a bigger pic
Oh look there's all the plating, floating around in the bottom of the crankcase! _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
