My gearbox fell to bits
mick
Fri Jul 07, 2006 7:48 pm » Post: #1 » Download Post
While taking the box out of a spare set of cases the selector forks (1 and 3) fell off their rod (no4). Is it normal that their rod stays in the cases and if so whats the procedure for getting the forks back on whilst trying to slide the box back in.
Chester362
Fri Jul 07, 2006 9:16 pm » Post: #2 » Download Post
Don`t worry!
As long as they`re not worn on the two ends that mate with the gears you can re-assemble the gearbox onto the cassette carrier plate.
Refer to the parts manual if you get stuck.
The selector forks are marked `L` & `R` if I remember rightly. It`s pretty self evident where they go if you take your time & think about it.
Sometimes the rod will stick due to suction caused by oil in the locating hole.
Oil can also cause a springy feeling when re-assembling due to a hydraulic effect as the rod enters the locating hole.
When you are fitting the gearbox back in be aware of the selector drum index roller spring ( No.9 in the diagram). This will get trapped between the carrier plate and crankcases if you don`t lever it into position before you tighten the plate into place.
rc46
Sat Jul 08, 2006 6:00 am » Post: #3 » Download Post
AND! remeber to remove the GPS on the sproket side, otherwise there is a chance you could damage it when you slide the box back (wonder how i knew that LOL) just refit when the box is back in, use a tourch to help line up the pin with the shaft. Very Happy
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Jul 12, 2006 3:21 am » Post: #4 » Download Post
All good advice so far.
The shifter fork shaft will come out of the case, it is not retained, just a sliding fit into it's housing.
Assemble the gearbox, including shifter hardware outside the motor first, then slide into position.
Be careful when you poke the countershaft through the countershaft seal though as it's not too difficult to damaged the seal or pull the spring off the inside lip of the seal if you're a bit rough.
mick
Wed Jul 12, 2006 7:45 am » Post: #5 » Download Post
Well the box itself is back in, didnt go too bad to be honest.
The only issue I have with it at the moment is its difficult to get gears but I'm assuming that this is because the box is dry and will free up once I put some oil in it and fire it up.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Jul 12, 2006 7:57 am » Post: #6 » Download Post
Hmmm. Should be reasonably smooth even without oil. I trust you oiled it up well before fitting.
mick
Wed Jul 12, 2006 8:15 am » Post: #7 » Download Post
Well to be honest I didnt put the gearchange lever on fully, It was changing ok out of the cases and it all went in smoothly so I'm hoping it'll be ok once I've put everything back where it should be.
rc46
Wed Jul 12, 2006 8:18 am » Post: #8 » Download Post
Did you remember to lift the spring out the way? as you slide the box back there is a spring that sits proud of the gear box plate you need to lift it up with a screw driver as you slide the last few cm's of the box in? then release and itll sit against the inside of the case. its the return spring i think if this is trapped it might cause a problem!!
mick
Wed Jul 12, 2006 8:25 am » Post: #9 » Download Post
rc46 wrote:Did you remember to lift the spring out the way?
Embarassed Forgot that bit, it did seem to slide in ok with no snagging.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Jul 12, 2006 8:51 am » Post: #10 » Download Post
That spring doesn't slide in on it's own, it must be coaxed in as rc46 says.
You'll have to do it again or you'll be getting jumping gears and a knackered transmission.
mick
Wed Jul 12, 2006 9:21 am » Post: #11 » Download Post
Embarassed Bollocks, which spring is it? The gear selector rod one (no 12?)
If so that may explain why ithe gear lever feels odd.
B"$£&*^$£ A£$$% %$£%$!!!!!!!!!
nsrmonkey
Wed Jul 12, 2006 9:42 am » Post: #12 » Download Post
harsh mick harsh........ Confused
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Jul 12, 2006 9:59 am » Post: #13 » Download Post
Not #12. It's #9
mick
Wed Jul 12, 2006 9:59 am » Post: #14 » Download Post
Cheers Matt
Monkey, Tell me about it. Crying or Very sad
Good thing is it's not that together I'll just need to whip the clutch housing off.
rc46
Wed Jul 12, 2006 1:37 pm » Post: #15 » Download Post
When you take the box out, towards the bottom right as you look at it youll see a spring hanging down, only 0.5 cms, itll be trapped just now so have a look before you slide the box back, if you still cant make it out, take a pic and send it to me and ill highlight the spring and send it back! but im sure itll be obvious! Confused thats how i felt when i put the box back and had no neutral light!!!!!! again the gps got damaged, because i forgot to remove it before sliding the box back in!!!
EMAIL: Alister_Cresswell@Yahoo.co.uk
