HRC derestrictor box
sparky
Mon May 15, 2006 6:00 am » Post: #1 » Download Post
HRC derestrictor box and loom.
will this still run the lights? if it doesn't I have read the thread where it can be hardwired into the stock loom.
it says it advances the timing, do I need to run high octane fuel?
will it still run the oil pump?
Re: HRC derestrictor box
Mon May 15, 2006 9:24 am » Post: #2 » Download Post
HRC derestrictor box and loom (presumably you mean part #30490-NKD-840 for the mc21 and the HRC loom)
Will this still run the lights? Not with the HRC loom no.
If it doesn't I have read the thread where it can be hardwired into the stock loom. Yes it can be, no I don't know how, Monkey's works fine
It says it advances the timing, do I need to run high octane fuel? No, but detonation is obviously more likely, check the jetting.
Will it still run the oil pump? Yes, it can.
Mon May 15, 2006 12:02 pm » Post: #3 » Download Post
I have one too, and wiring it in is simple. It sits in-line with the stock wiring, and you simply have to mate the plugs on the HRC box to those on the stock loom.
I removed the HRC plugs on the input side, crimped new pins on and inserted them into the stock loom, then filled the voids between them with silicone sealant (it's a standard aircraft 'battle damage repair' technique and works perfectly well).
The output plug connects into the PGM unit as per the normal loom.
Don
Mon May 15, 2006 4:32 pm » Post: #4 » Download Post
I went to the local salvage yard and found the exact same plugs from a late model Civic and wired everything up. I can now take the HRC box off in seconds and return it to stock and vice versa.
sparky
Mon May 15, 2006 7:36 pm » Post: #5 » Download Post
thanks for the info.
I just won one off ebay which comes with the loom.
It's goign to be for the street so I'm going to have to somehow wire it into the stock harness. I guess I'll have to ask for more info when the time comes.
sparky
got my HRC box and loom but....
Thu Jun 01, 2006 11:57 pm » Post: #6 » Download Post
I got the HRC box (NKD-8400) and the loom 32100-nkd-8401.
my problem is I was told this is the HRC loom but the plugs going to the pgm box are the same as the stock loom. I thought it would just plug straight into the HRC box. you I never thought I would need to mate the wires together even on the HRC loom. anyone know if I have a genuine HRC loom or if it's just a modified stock loom?
