I'm sure I still have it. a total of three are used. It looks like a common size so I bet Honda just changed the number. _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
At this moment in time there is stock of that part at hlcuk swindon uk, part number is good and there is no supersession to another number. i would suggest your local honda dealer to place this part on back order.or whatever the procedure is in texas. Regards Glyn
O-rings are O-rings, it does not need to be a honda one. Check a bearing shop or any good auto parts place. I get alot of my bearings and O-rings from www.mcmaster.com
Like cyclenut says, just go and buy an 8x1.5mm O-ring or two from any bearing shop, motor factor, diving shop... Home Depot/B&Q even probably!
What it is for? I'm guessing, by the size and from memory, the transmission oil pump? Regardless of what it is actually for, there is NOTHING special about the OEM part. _________________ Andy.
