Power Valve removal
j911brick
Power Valve removal
Tue May 02, 2006 4:13 am » Post: #1 » Download Post
How do I get the power valves out of the cylinders? I know the shaft has to come out but it doesn't want to.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Tue May 02, 2006 4:52 am » Post: #2 » Download Post
Two methods:
Use the RC valve removal tool - This is the correct way.
Use a series of washers piled up and use the L/H nut to slowly wind the shaft out - Not the best way but works.
Lock shaft in vice and smack cylinder with mallet - Wrong! et's the job done but will bend the shaft and might damage cylinder.
First option is the best.
j911brick
Tue May 02, 2006 4:59 am » Post: #3 » Download Post
How about a slide hammer? Can the proper tool be bought?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Tue May 02, 2006 5:34 am » Post: #4 » Download Post
slide hammer would work, but the proper tool is the way to go.
It is available to buy.
j911brick
Tue May 02, 2006 5:40 am » Post: #5 » Download Post
How much will it cost me and where do I get one?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
rc46
Tue May 02, 2006 5:58 am » Post: #6 » Download Post
http://tyga-performance.com/site/index.php?cPath=71_25&osCsid=54d70db71cae55178250a4472c1f9e9b
For all your NSR needs!!!!! Very Happy
j911brick
Tue May 02, 2006 6:28 am » Post: #7 » Download Post
I'll get that on order ASAP. I need to buy something else though. I hate to pay shipping on just item from so far away. Thanks for the tip.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
rc46
Tue May 02, 2006 7:16 am » Post: #8 » Download Post
No problem, Paul and Matt are easy to deal with, they do most things youll need for a NSR, if you cant see it, just ask.
Clarkie
Tue May 02, 2006 10:43 am » Post: #9 » Download Post
You'd think a couple of these would be available closer to home Andy? Wink
I'll take one if so....
Image Hosted by ImageShack.us
Tue May 02, 2006 12:23 pm » Post: #10 » Download Post
I refit the nut with a washer under it to the valve spindle, then use the claws of a claw hammer to lever the valves out. Use a piece of cloth between the hammer head and cylinder to prevent marks.
jeff350lc
Wed May 03, 2006 7:32 am » Post: #11 » Download Post
Dave Ett wrote:I refit the nut with a washer under it to the valve spindle, then use the claws of a claw hammer to lever the valves out. Use a piece of cloth between the hammer head and cylinder to prevent marks.
Shocked Shocked Shocked Shocked Wayne had his pants pulled down, and was given a good spanking for having the audacity to suggest that, when this same question was asked last week Wink
nsr.wayne
Wed May 03, 2006 5:58 pm » Post: #12 » Download Post
Crying or Very sad
Chester362
Wed May 03, 2006 7:07 pm » Post: #13 » Download Post
Where do you get these Honda HRC claw hammers from?
Could I get an HRC wooden handled Yankee screwdriver too? With uprated spring! Very Happy
