oil leak question (new problem now page 2 - pics)
nsr250eeeee
Wed Dec 28, 2005 5:48 am » Post: #1 » Download Post
I have some oil leaks on my nsr, i have been told its normal which i believe to be true cause the guy is very knowledgable, but I thought I should double check, just in case I am riding it one day and it blows up Razz
Pictures of the leaks are here:
http://au.pg.photos.yahoo.com/ph/wixynsr/album?.dir=/2ea3&.src=ph&.tok=phlwKKEBlPbEnJCp
Cheers.
Wed Dec 28, 2005 10:00 am » Post: #2 » Download Post
Well, for a start, I'd say that IMG_61 is chain oil, dripping down from the front sprocket (chain wheel)!
The other "oil leak" would simply appear to be what many call "2-stroke spooge". That's basically unburned 2-stroke fuel leaking past the exhaust gaskets, but often a sign of richness. It can also happen if you ride at low RPM a lot, as the motor only has a good clean burning RPM range when it's in its' power-band.
If you are happy with how it's running, then some high temp RTV sealant should cure most of the exhaust "leak".
dartwolf
    Send private message View user's profile MSN Messenger ICQ Number
Wed Dec 28, 2005 11:05 am » Post: #3 » Download Post
On my nsr it had the same problem, i fixed it by replacing the nuts and stud bolts on the exhaust pipe (where it joins the motor) ever since i did that it hasn't leaked any oil since the day i had it...
Honda NSR 250, 1990
nsrmonkey
Wed Dec 28, 2005 11:20 am » Post: #4 » Download Post
yup i also have/had a similar problem on mine, i took dave etts advise and sealed the exhausts around the gaskets and where the pipes join together with some silicone sealant.
have yet to see if it has worked as the bike is still in bits Very Happy
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
jkolewski
Wed Dec 28, 2005 3:12 pm » Post: #5 » Download Post
Hi Temp silcone worked for me too. New gaskets will help too.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
nsr250eeeee
Wed Dec 28, 2005 10:05 pm » Post: #6 » Download Post
thanks guys, i will probably try the silicone. Just to be sure though, if i leave it as is it definately wont cause any problems?
Wed Dec 28, 2005 10:58 pm » Post: #7 » Download Post
No problems, but you'll never get the fairings clean again. Also, to be pedantic (not something I'm often accused of) your exhausts aren't fully sealed to the motor, so it's not running as perfectly as it might be.
Not that you'll notice the difference, but you just KNOW it's there! Wink
Jezza
Wed Dec 28, 2005 11:10 pm » Post: #8 » Download Post
How hard is it to clean the silicone if you need to take the exhaust off again?
Jerry Lai
NSR250 [MC21SP]
Wed Dec 28, 2005 11:20 pm » Post: #9 » Download Post
No harder than it is to clean all the oil off!! Smile
nsr250eeeee
Wed Dec 28, 2005 11:30 pm » Post: #10 » Download Post
that begs another question, what is the best way to get rid of the oil in the fairing and on the engine?
nsrmonkey
Thu Dec 29, 2005 11:43 am » Post: #11 » Download Post
engine degreaser....gunk Question
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
nsr250eeeee
Thu Dec 29, 2005 12:31 pm » Post: #12 » Download Post
i have some methylated spirits ive never used, was wondering if that would work?
nsr.wayne
Thu Dec 29, 2005 1:17 pm » Post: #13 » Download Post
Use Petrol Exclamation
nsrmonkey
Thu Dec 29, 2005 1:24 pm » Post: #14 » Download Post
use fire Twisted Evil
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
mrpsychopath
Thu Dec 29, 2005 4:12 pm » Post: #15 » Download Post
pyro nutter Twisted Evil
faster-faster-faster-faster+pop. oh sh*t its fecked again.
