cleaning rubbers
aikawa
cleaning rubbers
Wed Oct 26, 2005 12:56 pm » Post: #1 » Download Post
response elements (BARE) of a number men, or solidify it by vitrification, and then the mRNA. Architectural characteristics and
Over weekend First Aid kit for vehicle, boat, residence, camping. Packed in a tight weatherproof container: Dressings 2 large sterile dressings 20cm x 19 cm 6 Always Thin Maxi pads individually
the corresponding fragment. The differ- mum at 550 nm for the reddish aqueous state may correspond to the ADP-bound
by pertussis toxin. G-proteins in the to either F or G protein are protective in amount of-structure in these altered
93' MC21
rc46
Wed Oct 26, 2005 1:33 pm » Post: #2 » Download Post
Ive put Brake lines onto most of my bikes in the past, its best to use NEW crush washers, and banjos, but if the banjo bolts are in good condition then just the crash washers, bleed the left side first then right, (as you sit on the bike) it can be done but a friend to help will bleed them alot faster, once done go back and forth 2 or 3 times to each side to make sure its free from air, At first youll think nothing is happening but itll work just keep bleeding. once you think your done check all bolts and bleed nipples the brake lever should feel hard and not squishy, if it still feels soft try a back bleed, take a caliper off the bike, losen the banjo at the top next to the master cylnder, and push a piston in youll see some air come out and that should be you all done, Always ride slow at first when youve done your brakes test them in a clear area and never do back and front at the same time! as for cans i cant say if you will do harm to the engine or if it helps the performance im not an expert, but i think the tyga ali cans are cheaper? if its just for looks
nsrmonkey
Wed Oct 26, 2005 2:10 pm » Post: #3 » Download Post
save a little more and you can buy some Tyga pipes, spend a little less and buy some cans from here and support NSR-world.
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
aikawa
Wed Oct 26, 2005 2:24 pm » Post: #4 » Download Post
THanks
if i do get only the cans wll i still have to rejet?
if i do, then i 'll save up and get the chamber/cans..
Wed Oct 26, 2005 2:57 pm » Post: #5 » Download Post
Aikawa, I'm afraid no-one on here will tell you it'll be fine, as every bike is different.
Some of us have swapped entire exhausts systems and not rejetted, others have fitted cans alone and siezed.
You SHOULD be ok with just a can swap, but check your plugs after riding a few miles just to see what's going on. What colour are they now?
aikawa
Wed Oct 26, 2005 3:28 pm » Post: #6 » Download Post
i changed them as soon as i got the bike which was like 2 weeks ago..
so i assume they are ok. see i live in japan on my own and dont have any tools to get to the plug...
SPENGILLY
Wed Oct 26, 2005 5:45 pm » Post: #7 » Download Post
YES! make sure you check all bolts!!! I changed my fluid while at work on a slow day & didn't tighten one bolt on the caliper, just hand tight. Confused I don't think it's good to answer phones & work on your brakes at the same time. I found out it was gone when I was on my way to Laguna Seca last year on Skyline Blvd, not the best place for brake problems. Embarassed Embarassed Something didn't feel right so I pulled over before I killed myself, very lucky I guess. I used a bolt from the kick stand & used a few washers form a propane delivery guy who passed by. Triple check everything!!!
jeff350lc
Wed Oct 26, 2005 6:52 pm » Post: #8 » Download Post
the best thing you can do when bleeding brakes, is to cable tie the brake leaver back to the bar and leave over night. bleed the brakes first as RC46 said. when you cut off the cable tie the next day all the air will have found its way back up the hoses and out the master cylinder.
i have used this method on three NSR,s and it never fails Very Happy
aikawa
Wed Oct 26, 2005 7:16 pm » Post: #9 » Download Post
thanks
should i also purchase air-free banjo bolts?? cuz my plan is to take it to te shop and get it put on. BUt i wont be abl to leave the bike overnight to bleed the brakes so....
oh and should i put cable ties on the rear brake lever aswell?
Wed Oct 26, 2005 7:20 pm » Post: #10 » Download Post
You could order the very trick HRC banjo bolts sold on this very site to help you bleed them. They can be found in the marketplace under "HRC"
Wed Oct 26, 2005 7:26 pm » Post: #11 » Download Post
It's up to you what you spend your money on but chambers and/or cans aren't worth anything really power wise on the '18 or '21 especially on the road (i.e they give about 2 bhp at the top and cost more mid range). They do sound nice but I know of a '21 that saw 66bhp on the stock chambers Shocked
A lot of the '21 restriction is in the wiring so if it's an increase in power (rather than just looking nice) you're after spend some of your 23000 yen on some tools and follow this.
You'll have done nothing except let the bike work properly in 4th, 5th and 6th so everything should be fine but do a plug chop* in 4th, if that's OK try 5th then 6th just to be sure as some hero may have jetted it down in the past.
Then mod the airbox, Tyga do this to theirs, other people prefer 4 1" holes in the top, mine has got two 1 1/2" holes in, whatever, the "problem" is the inlet in the airbox is not as big as the carbs, it doesn't take a rocket scientist to see this cannot be good.
The reason I say do this seperately is it almost certainly will require rejetting now as you are now allowing more air in, this is probably now the time to consider fitting the HRC (or JHA) jet kit.
*So, at the end of a long enough to get up to max revs in the gear you're checking it in, pull the clutch in, flick the kill switch, and coast to a halt. Remove the front spark plug and check the colour of the electrode. It should be a light tan colour if your settings are good. As it's probably standard it won't be loads too rich (black) but we're looking for grey or near white indicating it's too lean which means a gentle (Andy ) ride home and some larger main jets with some more of your 23000 yen.
Plenty to read about plug chops, jetting etc. on the forum and in the tuning bits so have a search.
maxim
Thu Oct 27, 2005 8:58 am » Post: #12 » Download Post
Best bit of advice ever and never fails... Unless as mentioned above you have the HRC banjo or Brembo radial master cylinder Wink
aikawa
Thu Oct 27, 2005 1:17 pm » Post: #13 » Download Post
HEy everyone THANKS for the input and help...
I also bought braided brake hose (reservoir to your master cylinder)
anyway i installed it and the hose is bending because the Master cylinder stay is constructed differently from the stock... do you think i can cut it and make it shorter so the fitment it perfect? and it seems to hit when i turn the steering all the way to the right
one more question i also bought some new front winkers, the question is do i just rewire it like it was on the stock winkers??
nsr.wayne
Thu Oct 27, 2005 5:54 pm » Post: #14 » Download Post
yes! Smile
