idles high when in neutral
aikawa
Mon Oct 17, 2005 7:09 am » Post: #1 » Download Post
i bought my mc21 a few days ago and it has stalled on me a couple times now. Some times when i'm at a light in neutral, the revs start getting higher(without the accel) and then it goes back down and stalls. Another time is when i'm in first gear and reving up down the street it seems to struggle from 6000 rpm... i changed the plugs and a mechanic told me for 2 strokes i need to pull it above 9000rpm so the plugs dont get covered with oil.. what seems to be the problem??
And also what gear do you guys stay in traffic? i am always half clutching and moving in first but i'm scared its gonna stall on me again so...??
any suggestions?
Barry_MC21
Mon Oct 17, 2005 10:02 am » Post: #2 » Download Post
Sounds like you may be running out of fuel. Rev's usually increase then die away when you get fuel starvation on a 2t. Confused Question
aikawa
Tue Oct 18, 2005 3:16 am » Post: #3 » Download Post
ok i got a new problem now, i started it up and was ready to go and dropped it into 1st then it shutdown, i started it up again and the same result.. whats wrong?
Tue Oct 18, 2005 6:57 am » Post: #4 » Download Post
Sidestand down?
If not, it sounds like you could be ruinning lean, and the bike doesn't have the power to cope with the clutch / gearbox drag. A high tickover can also be due to a lean mixture.
Have you done any work to it recently?
Have you checked the colour of the spark plugs? What is it?
aikawa
Tue Oct 18, 2005 12:49 pm » Post: #5 » Download Post
yeah i just changed the spark plugs. I checked the oil and it was a greenish color. I put in Castrol TTS... what could be wrong?
Tue Oct 18, 2005 12:51 pm » Post: #6 » Download Post
And the colour of the ones you removed? Did you fit the correct plugs?
mrpsychopath
Tue Oct 18, 2005 1:22 pm » Post: #7 » Download Post
Shocked check the fuel cap breather isnt blocked. had that prob myself a few times. Rolling Eyes
faster-faster-faster-faster+pop. oh sh*t its fecked again.
aikawa
Tue Oct 18, 2005 2:38 pm » Post: #8 » Download Post
yea i put in the right plugs. When i pulled out the old plugs they were well covered with oil... i dont know it starts fine now except for it struggles to get power in first gear.
Tue Oct 18, 2005 2:41 pm » Post: #9 » Download Post
Is it ok once you're rolling?
aikawa
Tue Oct 18, 2005 3:19 pm » Post: #10 » Download Post
yea its fine when rolling except when i start accelerating it struggles to go up then i put it into second and its fine its only in first
Tue Oct 18, 2005 4:05 pm » Post: #11 » Download Post
Ah. Youi sure you're not just struggling with the high first gear when you pull away? Is it ok in first once your rolling?
aikawa
Thu Oct 20, 2005 12:53 am » Post: #12 » Download Post
yeah after i pull hard in first it seems to be ok after that.. what seems to be the problem?
Thu Oct 20, 2005 3:24 am » Post: #13 » Download Post
Check through your fuel system. As said previously, the revs rising at tickover then stopping is usually a sign of fuel starvation. Strange that it runs when you're into second though.
Pull the carbs apart and give it a good clean, and check your jetting while your at it.
Also check your oil pump settings for good measure.
As for revving it over 9 grand to keep things clean that's a little over the top. Pretty much all stock strokers will run all day well under this mark. Even my 300 will tick through the traffic at 3000rpm for at least half a mile before it starts to stutter and complain.
aikawa
Thu Oct 20, 2005 12:02 pm » Post: #14 » Download Post
i asked about the problem to the shop i bought my bike and he said that its not a problem it only happens when the bike isnt warmed up.. is that true? does your guy's bike lag in first until your bike gets warmed up?
Also, my gas seems to burn very quickly. I filled up already twice this week. around how many clicks(kilometers) do you guys put it in reserve. i usually put it on reserve after around 90 kilometers.. but i guess thats because i rev up to like 9000...
Barry_MC21
Thu Oct 20, 2005 12:07 pm » Post: #15 » Download Post
90kms is about 50(ish) miles I think. I dont go onto reserve until about 120miles, or 200 kilometers.
Confused
