New Member with An MC18...wait.....no...an MC16...yes MC18
Page 24 of 24  Goto page Previous  1, 2, 3 ... 22, 23, 24 Download Topic
Tue Dec 02, 2025 2:45 am » Post: #346 » Download Post
I've just moved the Members' Builds area out of the "Members" area and into the "NSR Discussion" area, to move/group relevant topics, and give them some more focus.
Please let me know (a) if you're OK with this by replying to this post so you don't lose any bookmarks etc.
Hudtm60
Mon Dec 29, 2025 8:02 pm » Post: #347 » Download Post
Hello Everyone,
It took a PM from Andy to get me to post again. Long story short, since October work got very busy AND had to move house. Everything fun got sidelined.
I last left the NSR with a to do list stuck to it reminding me to swap the coils to see if the intermittent firing on one cylinder followed the coil- but I haven't got around to that and ironically the time came to I move the NSR yesterday from the old garage to the new garage- it's a mere 7 miles. I figured that if I was gentle with it, it might play nice.
In terms of getting it from one place to another under it's own steam- the result was good. I wish I had video but I can't get the GoPro to talk to my new internet. In words: it'll run on two cylinders up to about 6,000 rpm IF I am very careful in only gradually opening the throttle, and that process can get you up to 70mph so that was kind of fun. However, like before, it won't tolerate a handful, nor is it interested in going above 6k on two. It's like it's a very weak spark that can't handle too much fuel before it gets extinguished-but I'm clueless to be honest.
Coil swap pending!
Still running around half naked.
In the new place on the old lift where it seems to have spent most of it's life. a real mechanics brain would help.
Hudtm60
Sat Feb 07, 2026 12:30 am » Post: #348 » Download Post
Hello,
back again after some hopeless purchases. I couldn't help myself getting a new stator via Jauce. https://www.jauce.com/auction/h1218235812 I've got it in my head that the problem is an electrical one and thought it would be great to at least take it out of suspicion even if the more educated would tell me it has nothing to do with the issue of only running on 1 cylinder....the rear one.
It even has an appropriate grommet..
swapping them out...
Getting ready to remove... the original coils.
...here they are....spoiler alert..these originals... aren't the problem...
with these other ones that arrived via Jauce...the problem is still there.
one has to wonder....is it the pick ups...or as they are decribed in the manual...Pulse Generators?
Good and Bad...just to remind me which one works and what doesn't. I've swapped out everything electrical apart from the pick ups which, let's be honest, they are probably fine....but has anyone had any issues? They do exist- but who knows if they work. https://www.jauce.com/auction/l1218608590
I think I'm resigned to the fact that it's a fueling issue so I think the next step is is to pull the carbs and take them to pieces, again, and also check the reeds while I'm in there.
To re-cap the front cylinder isn't kicking in....you can hear it trying at very low revs but it just won't catch. To be honest I've got nothing but time, so would consider sending the carbs off to a pro to go through them just in case I've been doing something wrong all along. it's quite possible. Whole thing is odd as for a very short and inconsistent time it ran on two.
Pretty sure I have the plumbing right.
In (brackets) is the stock jetting
Compression. Any compares?
Rear 120psi after 17 Kicks and throttle wide open- but engine is cold.
Front 115pssi after 17 Kicks and throttle wide open - but engine is cold.
