MC21 fork build
Camo
MC21 fork build
Tue Jul 14, 2020 11:16 pm » Post: #1 » Download Post
What determines where the lock nut should be on the damper rod on the front forks. Fitting new seals and giving everything a once over and one lock nut is to the bottom of the thread and the adjuster down to it one is about 8mm from the bottom. Not sure what this affects but imagine they should both be the same but where is that / how is that set?
Cam
Max
Re: MC21 fork build
Wed Jul 15, 2020 6:37 am » Post: #2 » Download Post
Camo wrote:What determines where the lock nut should be on the damper rod on the front forks. Fitting new seals and giving everything a once over and one lock nut is to the bottom of the thread and the adjuster down to it one is about 8mm from the bottom. Not sure what this affects but imagine they should both be the same but where is that / how is that set?
Cam
Are you talking about the pre=load adjuster or damping needle?
If it is the needle, you wind out the needle to fully out then turn it in 10 clicks. You also spin the lock nut down to the bottom of the thread.
You then screw the fork top onto the damper road until it just touches the needle finger tight. Adjust the needle three clicks out.
Then spin the locknut up to the bottom of the fork top assy. and tighten (try not to let the fork top assy. move)
If it is the preload adjuster then then I don't think the lock nut on the damper rod has anything to do with that adjuster, it only concerns the damper rod.
Adjust the preload nut to its weakest setting.
Spin the locknut to the bottom of the thread and fit on the fork top to finger tight, then bring up the lock nut. Tighten to factory torque value.
That being said both sides should always be equal 👍
I have not worked on the non-SE type forks so this is guidance from looking at the workshop manual, you may be seeing something different.
Good Luck
Max
Wed Jul 15, 2020 6:42 am » Post: #3 » Download Post
This is a handy read...a fork overhaul performed by Tyga
http://tyga-performance.com/images/00psm/02tpfitman/08fitmantuning/14mc28frontfork.pdf
Max
Wed Jul 15, 2020 6:43 am » Post: #4 » Download Post
And this...
http://www.nsr250.net/forums/viewtopic.php?t=15068&highlight=
Camo
Wed Jul 15, 2020 7:20 am » Post: #5 » Download Post
They are 'r' forks and it is just the lock nut under the adjuster I am talking about
I will have a look through the guides you sent thanks for those ,. When the nuts weren't equal is when I got to thinking haha
Max
Wed Jul 15, 2020 10:27 am » Post: #6 » Download Post
Camo wrote:They are 'r' forks and it is just the lock nut under the adjuster I am talking about
Important to have your nuts equal Camo ROTFLMAO
