MC18 Swing Arm bearings
tleighbell
Fri Mar 16, 2018 9:31 pm » Post: #1 » Download Post
Any suggestions where to source all the bearings, bushings, seals etc. that go in MC18 swingarm including the shock linkage/pivot? I did see a kit from Oz on ebay, looks a little pricey at 72 quid. Ordering the parts individually is complicated by the fact that the online parts manual does not list part numbers for all the parts shown in the drawing of the swing arm itself (the drawing of the shock and linkage seems to be OK), and some of the descriptions don't match the drawing which makes me question some of the parts numbers that are there. All Balls has no listing for the NSR but I wonder if the parts from another more common bike might fit. Even getting reliable part numbers for the swing arm bearings, collars, bushings, seals etc. might help.
Also, for the rear brake caliper bracket/holder, the bushing in the big hole where the axle goes through (i think?) is worn out. Is there a part to replace that or do I need the whole thing? There is a used one on ebay but I'd be more confident with something new.
Finally, i need the bushings for the Heim joints in the rear brake torque arm and any associated seals. Again the parts manual does not show the part numbers for these bits. Part numbers would be helpful if anyone has them.
Thanks all.
Sat Mar 17, 2018 11:28 am » Post: #2 » Download Post
The guide on CMS is very good and their service is excellent. You might pay more for some rare NLA parts.
https://www.cmsnl.com/honda-nsr250r2-1988-j-japan_model49608/partslist/0176.html#results
Stephen did say there was no real need to replace them, but I had my swinging arm re-anodised. Any bearings and seals can be ordered from the codes on each item from any good bearing supplier. I only ordered the ones that were NLA and all went back together with no issues. One of the seals that I ordered from David Silvers looked like a non-Honda substitute
herb
MC18 swing arm bearings
Sun Mar 18, 2018 8:19 pm » Post: #3 » Download Post
Thanks Rob. that should do it.
