Hi
I just cut the wirless to match HRC card, when everything done, HRC card put in, it shows SP about 1 mins, i was so happy... But I can not start to engine, I tool the plug to check, there's no fire at all, that's why I could not start the engine. Don't know why.. also I connect 3 lines back to stock wire, then its start.
I plan to have HRC card and stock switched, I only cut 3 lines, then I check the Wire Splice,I did not cut the green light to connect the other 3 line at 4th step( only cut light green/ red. green/pink. green/white) I don't know if that's becasue of the reason. can some one help me.
appreciate.
1996 HONDA RS250
1995 MC28 NSR250 SE red/white/green
1994 MC28 NSR250 sp W/ RS250 engine
