Need help with rubber inserts
Fri Jul 01, 2005 2:51 pm » Post: #1 » Download Post
The rubber mounts which attach the airbox to the carbs have been separated from the air box. I noticed some kinda glue with previously fixed then in place. What should I be using to re glue these things in place.
I’ve a spare MC28 airbox, could I use this instead although I know the two aren’t the same.
cgallant
2001 Honda RS250
Fri Jul 01, 2005 3:03 pm » Post: #2 » Download Post
You should be able to use a high temp/fuel safe sealant (RTV or other type material).
If the boots are to beat up, the simple wont stay in place on the air box, then you would want to order some new ones from Honda.
Charles Gallant
Mon Jul 04, 2005 8:15 am » Post: #3 » Download Post
I think the boots have gone a little hard as they were really difficult to get off the carbs, not like my MC28. Might have to do a little surfin to see if I can get some elsewhere.
fstnsr
Mon Jul 04, 2005 8:46 am » Post: #4 » Download Post
i just had to put some on a 21 and they were as hard as a rock ad were NOT going on so i pulled them out put a pot on the stove boiled water put the boots in and boild they for a few min and not they are as soft as a babys bottom
94 mc28 SE
Clarkie
Mon Jul 04, 2005 8:58 am » Post: #5 » Download Post
Whenever the carbs come off [every other day huh Steve?!! Shocked ] I am NEVER sure I have the rubbers seated proper.
I may try the hair dryer on them next time....
Image Hosted by ImageShack.us
Luke F
Mon Jul 04, 2005 12:02 pm » Post: #6 » Download Post
Hey tom
Just gone through the same deal, I first scuffed up the old air box with some fine wet and dry. Then used a two part epoxy glue like areldite, once that went off I went round with a load of silacone. It was messy and no work of art but so far so good, couldnt swear it will last foe ever.
luke
Farting is funny
