2t Oil 3-way connector
Roman250
Mon May 14, 2012 8:07 am » Post: #1 » Download Post
I have a new 3-way connector to replace this old one, but am unsure about how to do so. Will I need to bleed the system afterwards?
Hobbit210
Oil pipe
Mon May 14, 2012 8:55 am » Post: #2 » Download Post
As a matter of safety, not being an old hand though, I would bleed the oil system. If for nothing else just for 'peace of mind'. Belt and braces maybe but worthwhile in my opinion.
Mike
Roman250
Tue May 15, 2012 3:04 am » Post: #3 » Download Post
Im behind on the basics. To bleed the pump, I do what exactly: Open the bleed screw and... turn the throttle until there are no more bubbles? Bled brakes just never an oil pump.
EDIT: replaced it and bled the system, a bit messy but easier than i thought. hopefully it runs well
Hobbit210
Wed May 16, 2012 7:20 am » Post: #4 » Download Post
Hi
This website/Forum has a superb motor build section where you can find full details on bleeding the system. Undoing the bleed bolt and letting the oil run through should be fine...but me...sadly I'm belt braces and then another belt. Rolling Eyes Rolling Eyes
Mike
