torque spec question
Jim
Wed Feb 13, 2008 4:09 am » Post: #1 » Download Post
Hi all,
Can anyone tell me what the proper torque spec is for attaching the exhaust headers to the 2 studs on each cylinder? - this is for a Tyga rather than stock exhaust, if that makes any difference. Thanks.
-Jim
'93 MC21
Jim
Thu Feb 14, 2008 5:16 pm » Post: #2 » Download Post
anyone? someone please save me from myself - when in doubt I usually overtighten! how about 20 ft lb - seem about right?
-Jim
'93 MC21
parky69
Torque Settings
Fri Feb 15, 2008 8:17 am » Post: #3 » Download Post
Hi Jim,
Look at the following URL & this will help you out. Very Happy
http://www.dreamgate.ne.jp/NSR/technical/torque_settings.html
regards
Mark
Jim
Fri Feb 15, 2008 2:32 pm » Post: #4 » Download Post
Mark,
Looks like 20.2 for the MC28, so I'll assume the same for the MC21. I and my bike thank you! Very Happy
-Jim
'93 MC21
cgallant
2001 Honda RS250
Fri Feb 15, 2008 2:46 pm » Post: #5 » Download Post
The cap nut that screws onto the studsis 2.8 kg-m (20.2 ft-lbs).
The torque settings from a stock exhaust VS the way TYGA uses a flange that the TYGA pipes slide onto and use springs shouldn't be that different. The stud and nut are still the same size and being used in the same application, which is what really determines the needed torque settings.
Charles Gallant
Jim
Fri Feb 15, 2008 5:02 pm » Post: #6 » Download Post
thanks Charles - sounds like 20 ft-lb should be about right for the Tyga pipe too then.
-Jim
'93 MC21
