How do you remove the TPS? (MC18)
mattc
Sat Jun 09, 2007 1:51 am » Post: #1 » Download Post
Probably a stupid question but does it just pull off or what?
I see theres a screw above it but its hard to get at and on my bike is a security type screw i cant undo anyway.
Hi to everyone by the way, i'm matt from nz - completely new to bikes (an nsr is a pretty good place to start though!)
maxim
Sat Jun 09, 2007 8:53 am » Post: #2 » Download Post
Why do you want to remove it? It's not a good idea to get rid of it completely...
Sat Jun 09, 2007 5:42 pm » Post: #3 » Download Post
Once the screw and retainer is removed the TPS can just be pulled off the side of the carb. There is nothing really holding it.
But like Maxim says, unless your running some sort of race ign system or non TPS carbs (the TPS still need to be on the bike even with non tps carbs)they run a whole lot better with the TPS.
mattc
Sat Jun 09, 2007 11:11 pm » Post: #4 » Download Post
Just want to unplug it to set the rc valves - turn ignition on, then off, then remove tps then ignition on then adjust them to the marks?
Sat Jun 09, 2007 11:28 pm » Post: #5 » Download Post
Just unplug the plug, leave the TPS alone.
Follow the wire from the TPS itself, there's a plug tucked away on the bracket the air solenoids hang off.
(this may be a lie on an MC18)
mattc
Sat Jun 09, 2007 11:49 pm » Post: #6 » Download Post
Yeah i just realised it unplugs further back - feel like a bit of a dork now!
Thanks for the replies anyway guys
maxim
Sun Jun 10, 2007 11:20 am » Post: #7 » Download Post
They're bloody hard to set up and every one is different (due to the tolerance of the potentiometer), so don't take it off, that's why it has a security torx bolt holding it in place... Your bike will make about 10bhp if it's set up incorrectly...
