strange noise
fenton
1990 Honda NSR250 MC21
strange noise
Tue May 08, 2007 9:59 pm » Post: #1 » Download Post
took the bike out tonight after it being out of order for 3 weeks warmed it up and set off when i stopped at the lights and reved it a bit it sounded (the only way i can describe it) like a jet engine wooshing type of noise when it was reved i have no clue as to what the noise is has anyone had anything like it ?
lilblakcooper
Wed May 09, 2007 7:10 am » Post: #2 » Download Post
yes mine made that same noise just before the r/h main bearing failed.....
i hope its not the case with yours mate.
good luck Sad
fenton
Wed May 09, 2007 3:48 pm » Post: #3 » Download Post
it had a new crank 2500-3000 miles ago but you never know.............
is there any guarantee on new cranks andy ?
Wed May 09, 2007 5:44 pm » Post: #4 » Download Post
No idea. It was brand new from TYGA, as you know.
Wed May 09, 2007 5:44 pm » Post: #5 » Download Post
Was it one of the repro cranks or a real one Andy?
Wed May 09, 2007 5:47 pm » Post: #6 » Download Post
No, it was brand new Steve.
No reason why that shouldn't be good for 30,000 kms.
fenton
Wed May 09, 2007 7:37 pm » Post: #7 » Download Post
only asked you mate because you seem to deal with tyga a lot. dont think it will be the crank anyway. just speaking with roy and it came to me what it mite be will tell you when i have a look when it stops pissing down...........
Wed May 09, 2007 11:31 pm » Post: #8 » Download Post
Not the water pump or water pump drive gear?
fenton
Thu May 10, 2007 5:45 pm » Post: #9 » Download Post
i am going to pull the motor apart this weekend just to be safe i will let you know what i find........................
Fri May 11, 2007 1:47 am » Post: #10 » Download Post
Andy's got a good point there.
I've had quite a few NSRs that make a fierce whirring noise. Change the water pump bearing and seals and good to go.
The crank 'should' be ok. If it was a new 'un then you shouldn't be having problems with it, unless it was fitting by monkeys.
