not smokin
biatchy
not smokin
Wed Oct 12, 2005 8:55 am » Post: #1 » Download Post
hi started up my bike today..
as you know i have recently rebuilt...new spark plug in one cylinder(i broke the other one, so the lower one still has the old one)
anyway...both cylinders fire and the bike revs nicely..
one thing tho...there is like no smoke comin from the lower cylinder(the one with old sparky)
when i rev high there is a few puffs here and there while the other cylinder is smokin nicely.
i had a look at the old plug and it was wet....
i dont understand how there iscombustion but there is no smoke?
gonna get a new plug anyway and see...but any ideas tho?
cheers.
Philip Ahn
MC21 NSR250R
im poor...
rc46
Wed Oct 12, 2005 9:47 am » Post: #2 » Download Post
maybe now that youve done a rebuild the carbs need to be set!! it could be that before it was set up to run rich but noe its to much, I dont know for sure just an idea
Wed Oct 12, 2005 1:13 pm » Post: #3 » Download Post
No smoke and a wet plug? Sounds like it's not firing at al to me. Check the pipe is getting hot to be sure it's firing.
biatchy
Wed Oct 12, 2005 1:41 pm » Post: #4 » Download Post
yeah its definetly firing...the pipe is hot...as hot as the working one.
when i feel the exhaust comin out it feels a little weaker than the working one.
i will get new plug for that cylinder tomorro and see what happens
Philip Ahn
MC21 NSR250R
im poor...
Wed Oct 12, 2005 2:13 pm » Post: #5 » Download Post
Sounds as simple as that. Check the coil connections though, we've seen a few with pitting on the spade connectors of late, causing a voltage drop and crap spark.
biatchy
Thu Oct 13, 2005 7:11 am » Post: #6 » Download Post
changed spark plug.
all is good now..both cylinders are smokin good on start up!
cheers
Philip Ahn
MC21 NSR250R
im poor...
biatchy
Fri Oct 14, 2005 3:23 pm » Post: #7 » Download Post
hi, i just wanted to add...
i have pulled out the lower spark. the one that is messin up...and it is wet fouled...i will chek my connecting coil thing also.
is it my crank seal? please tell me no. Sad
also...i have never had a 2 stroke before...and the crank case is quite loud when idling..clank clankity clank...soudns like it is hitting..is that normal?
cheers
Philip Ahn
MC21 NSR250R
im poor...
Jezza
Sat Oct 15, 2005 6:45 am » Post: #8 » Download Post
I'd like to know the answer to that too. When my bike is idling, it's so noisely clanking. Even though it was in neutral, I had always thought it was just my dry clutch Confused
Jerry Lai
NSR250 [MC21SP]
nsrmonkey
Sat Oct 15, 2005 7:41 am » Post: #9 » Download Post
my old R used to blow cold and didnt smoke much from one of the pipes and i am afraid it was my crank which Andy then replaced for me Very Happy .
the clanking could be your dry clutch if you have one the R doesnt as standard but when idling my clutch (dry) sounds more like 'ting.....ting' than a clank clank, although i am no exspert it aint sounding to great for ya. Sad
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
fenton
1990 Honda NSR250 MC21
Sat Oct 15, 2005 9:36 am » Post: #10 » Download Post
the "clank clank" noise my be worn gearbox bearings, i had a similar noise on my nsr 125 also check that its not runng rich or to lean this can make some funny noises to
biatchy
Sun Oct 16, 2005 1:48 pm » Post: #11 » Download Post
damn....yeah that cylinder is actually blowin "colder" smoke than the other one and not as much smoke.
well the bottom cylinder is running rich...it is wet fouled...
but is that due to the jetting ?
or is it actually fouling because of the possible messed up crank?
i guess it is hard for you guys top tell from reading off your screens... Wink
Philip Ahn
MC21 NSR250R
im poor...
fenton
Sun Oct 16, 2005 6:43 pm » Post: #12 » Download Post
make sure the jetting is right first, also see if the spark plugs are the same heat range have a look at the air fillter it my be clogged if all is fine take off the stater cover and see if ther is any movement side to side or up and down of the fly wheel this can tell you if the journal bearings are worn
biatchy
Mon Oct 17, 2005 12:09 am » Post: #13 » Download Post
ok cool...fenton..
i will have a look at those and get back to you...
cheers
Philip Ahn
MC21 NSR250R
im poor...
Mon Oct 17, 2005 8:11 am » Post: #14 » Download Post
can you get to listen to another two stroke? They do sound loud at idle compared to a four stroke, so the noise may be normal. No point panicking until it goes pop eh?
As for fouling the plug, it's either a badly setup carb, or the ignition circuit. Try swapping the coils over to see if the fault changes to the top cylinder.
biatchy
Mon Oct 17, 2005 9:11 am » Post: #15 » Download Post
good idea dave...i will have a go at that also and let you guys know what happens...
yeah...i havent had the chance to listen to another 2 stroke yet...
any of you melbourne boys wanna come down to my place and have a chat?
wouldnt mind meeting some of you guys anyway..
cheers
Philip Ahn
MC21 NSR250R
im poor...
