This pump came off a low miles MC28SE which was being turned into a race bike in Japan. Looks in nice clean condition.
One of the brass outlets seems to be at a slight angle, I am not sure if this is intentional or not.
Check to see if it looks the correct assembly for your bike as there are a couple of variants.
Note: you will also need the small flat metal bush which fits on the end of the gear drive in the engine case.
£50 + postage
