First run today of my first NSR after total strip down of engine to find reason for excessive smoking, previous owner had engine problems. Runs like a dream now. Looking forward to some summer miles on Welsh back roads.
Hi there
Glad to hear you sorted the motor out it has been in hibernation for a few years now,but pleased to know its back in action,
It sure is one pretty little bike,
All the best with it,
jonmac _________________ John
Nice one, glad she's back on the road, dont stick too many pictures of her up though, i might just get all bleary eyed. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
I came across some cases from a later model with oil feed to RHS crank bearing so used them, other than that just a careful rebuild as most parts were replaced by previous owner. I am a bit concerned about the cylinders, they had been recently replated? but there are many areas on the thrust surfaces with no cross hatching at all. I need to either revert back to the wet clutch or obtain a good clutch gear (22130-KV3-840) for the dry clutch as mine has tooo much movement between the 2 gears and sounds rough at idle. Need some lamps then MOT Tuesday.
Hi Martin
It sounds very much like you may have a missmatch in you primary gears,MC 28 runs a 24 t crank gear and a 60 t clutch hub gear also a 25 t water pump gear, MC 21 runs 25 t primary,59 t clutch hub gear and a 26 t water pump drive ,
Only the Motor company knows why this was changed ?????,
I wouldnt ride it any more until you check it out,It sounds to me like this could be your problem,
Goodluck and keep us informed what the issue was,
jonmac. _________________ John
Hi again Martyn, i didn't realise you had bought it off Mike with the motor disassembled and you had to rebuild it again, thats a shame really, considering the wet clutch motor in it had had so much money spent on it, good luck with the mot. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
I had to strip the engine completely as the crankshaft seal was inserted incorrectly, hence massive smoke., so I took the chance to start from scratch. The dry clutch was on the engine, the free play I have John is not between the primary gear and clutch gear but actually on the clutch gear. Holding the large gear I can move the clutch basket side to side and its not the bolts but appears to be between the riveted inner and outer parts.
Les, I appear to have parts for a wet clutch with the spares from Mike, I take it from your comments that it is a good one. I will check it out and hopefully its all there so I can go back to wet.
