Leak down question.
alrsv1
Leak down question.
Mon Feb 06, 2012 10:38 pm » Post: #1 » Download Post
Hello everyone,
I've read about the leak down test you can do to check the crank seal by pouring fuel/oil mix into the top of the engine and
see if it leaks out the bottom. So as I had the barrels and pistons out I thought I would do this. I poured some mixture in the
top engine opening (onto the crank) and left it for a bit.
So far it hasn't leaked. Now, how do I get the mixture out? Or I have I done it wrong?
Don't say turn it upside down. Smile
Cheers...
Al.
Cheers....
Al
Bikes:
GPZ900
NC30
NSR250SE
RGV250 vj22
anonymous.shyster
Tue Feb 07, 2012 12:24 am » Post: #2 » Download Post
Take the crank out.
No, I'm joking. Get a syringe and a bit of hose and suck as much as you can out. Leave the rest to evaporate.
toneless
Tue Feb 07, 2012 1:33 am » Post: #3 » Download Post
I put a cockroach through the spark plug hole.
If it doesn't escape in 5 minutes then I call the leakdown test successful.
Sorry, no offense but I couldn't resist. Laughing
I reckon you will only be able to diagnose major air leaks on side oil seals with this method.
Use a syringe with a flexible hose at the end as already mentioned ...and lots of rags.
Aforementioned parts will be helpful for brake bleeding as well. Rolling Eyes
2t-racelab.com
