Cylinder studs
MAGTEK
Guest
Cylinder studs
Tue Mar 16, 2004 8:04 pm » Post: #1 » Download Post
Does anybody know if cylinder studs from a 93 NSR250 SE are the same as any other motorcycle that would be available in North America i.e. CR125 - 250, RS250, etc.
Tue Mar 16, 2004 9:49 pm » Post: #2 » Download Post
Yes, they are identical.
Part number 94050-08000 is a global Honda part number for an M8 "flanged" nut. (The head is 12mm)
MAGTEK
Guest
Tue Mar 16, 2004 11:31 pm » Post: #3 » Download Post
Is this part number for the nut or the stud, because Im looking for the 6 studs that are on the cylinder.
MAGTEK
Guest
Tue Mar 16, 2004 11:32 pm » Post: #4 » Download Post
I think the part # is 90032-KV3-830 for the studs.
Wed Mar 17, 2004 1:42 am » Post: #5 » Download Post
Sorry, a case of me mis-reading your initial post!
There are actually 3 different studs in use on the NSR's barrels, depending on whether you are replacing the upper or the lower head. Given that you have quoted the part number 90032-KV3-830 I will hazard a guess that you are only talking about studs relative to the lower head?! For a complete set for the lower barrel/head you will need 3x 90031-KV3-830, 2x 90032-KV3-830, and 1x 90033-KV3-830.
The upper head/HRC conversion uses 6x 90031-KV3-830.
There's nothing significantly special about these studs, apart from the KV3 in their number! If you take one along to any dealer (or automotive parts supplier) they will be able to match one up with similar dimensions.
Sorry for the confusion.
