Mc18 cylinder head ???
Gazpar
Wed Jan 13, 2016 9:18 pm » Post: #1 » Download Post
Hi everyone new to forum
Can anybody help me ???? I have got a mc18, on stripping the engine the rear cylinder head is full of debris and det marks.... It's fooked !!!!
The part number is KV3 GR E1 I have found another to replace but part number is KV3 GR E2
What's the difference ????? If any
Thanks
cgallant
2001 Honda RS250
Wed Jan 13, 2016 10:22 pm » Post: #2 » Download Post
Gazpar,
I am assuming that is the number that is on top of the cylinder head (as in the casting)?
The actual honda part numbers are slightly different.
For RKII, the part numbers are 12210-KV3-000 (or 12210-KV3-010 for the front head and 12215-KV3-000 (or 12215-KV3-010) for the rear head.
Fo you have a RKI or an RKII (1988 vs 1989)?
Someone else may know the correlation between whats in the casting on the head VS the actual part number and be able to give you further details.
Gazpar
Wed Jan 13, 2016 11:06 pm » Post: #3 » Download Post
Yes sorry numbers cast on top of heads, look the same
Mine is 89 r5k
sami1
Thu Jan 14, 2016 10:09 am » Post: #4 » Download Post
Hi, I have just sourced an 89 year r5k engine and have the same heads with the casting number KV3 GR E1 on it.
These heads are slightly taller than the 88 year r2j/r4j heads.
If the replacement heads are the same height with the casting numbers ending E2, then I am guessing they are for a r6k late 89 year engine.
I doubt there are any differences.
dazsegger
Thu Jan 14, 2016 7:41 pm » Post: #5 » Download Post
H gazpar
I live just up the road in Long Preston. If you fancy meeting up in the summer give me a shout.
I have an mc16 ready for mot in the spring.
Daz
stink wheels forever.
ian_gt
Wed Jan 20, 2016 9:03 am » Post: #6 » Download Post
Can MC16 heads be fitted to an MC18 and vice-versa? I'm looking for new heads for my MC16 and there seem to be various different castings around.
Wed Jan 20, 2016 9:40 am » Post: #7 » Download Post
MC18 heads can be used on the MC16, but they are slightly higher compression, so check the squish.
Also, be aware that the rear coolant hose routing differs slightly, and the MC18 head has no provision for the additional hose the MC16 head uses.
