NSR 150 SP RC Valve Pulley Adjustment
Lucky-Luke
Tue Dec 22, 2015 3:39 pm » Post: #1 » Download Post
Anyone familiar with doing this? I have a 2001 NSR 150SP, Australian model, but these instructions don't seem.... right.
On my stock bike, the only marks I have on the pulley body are, Low, High and the pulley wheel mark for aligning, but no marks for actually aligning the pulley with the HIGH or LOW mark.
If I don't have these marks.... how do I do this!?
nxrsr20
Tue Dec 22, 2015 6:17 pm » Post: #2 » Download Post
Can you post a photo of your cylinder? that sounds odd.
Lucky-Luke
Wed Dec 23, 2015 7:41 am » Post: #3 » Download Post
nxrsr20 wrote:Can you post a photo of your cylinder? that sounds odd.
In the photo you can see a very thin line on either side, I guess that's the mark, but it's almost impossible to see it without a picture Confused Shocked Embarassed
When you look at it in person, the area looks brushed, so it's very hard to determine the accuracy of the alignment :/
Lucky-Luke
Wed Dec 23, 2015 7:47 am » Post: #4 » Download Post
Check that the gap between the notch on the RC valve timing pulley and "H" mark on the cylinder is within 0.3mm
This might be a poor translation from Thai, just to make sure I do this correctly.
The aligning mark on the pulley needs to align at least within 0.3mm of the "H" aligning mark, circled in red.
nxrsr20
Wed Dec 23, 2015 6:40 pm » Post: #5 » Download Post
That's the marks you are looking for.
BTW, Andy may be able to chime into this, somewhere in the deep dark pits of my memory I thought that the 150 was supposed to use the HRC tuning method, not the one you dug up (where did you dig it up from)?
Lucky-Luke
Wed Dec 23, 2015 7:20 pm » Post: #6 » Download Post
nxrsr20 wrote:That's the marks you are looking for.
Found an 'english' version of the NSR 150 Honda service manual. Not sure where, I still have the .pdf on my PC.
Also, HRC tuning method?
Lucky-Luke
Thu Jan 14, 2016 6:39 am » Post: #7 » Download Post
Bump. Curious about this hrc method
