Brake fluid level
dazsegger
Brake fluid level
Sun Jun 21, 2015 12:43 pm » Post: #1 » Download Post
Hi guys
When filling the reservoir do I fill to the correct level and then fold the rubber boot inside itself before fitting and then top cap on?
The rubber is quite big in length so brings the fluid up to over flowing the reservoir.
Some reservoirs have a rubber that is straight across so isn't an issue.
My bike is an mc16.
Thanks in advance.
Daz
stink wheels forever.
Sun Jun 21, 2015 8:53 pm » Post: #2 » Download Post
The level should be at the upper mark with the rubber diaphragm fitted.
It might sound obvious, but just in case, sometimes the diaphragm can be "sucked" inside out if the fluid or pads run low, so make sure it's fitted correctly.
dazsegger
Mon Jun 22, 2015 6:42 pm » Post: #3 » Download Post
Thanks for reply Andy
The diaphramn is quite deep so I presume I fill reservoir to low mark and when diaphramn is fitted it brings level up to top mark?
Daz
Mon Jun 22, 2015 11:14 pm » Post: #4 » Download Post
That's pretty much the size of it! Smile
dazsegger
Wed Jun 24, 2015 5:27 am » Post: #5 » Download Post
Thank you Very Happy
