Finally getting up to fixing my MC16
jumpjuly88
Wed May 06, 2015 5:02 am » Post: #1 » Download Post
Howdy, new member from Brisbane , Australia here.
I own a couple of two strokes, a MC16 NSR250 and an RZ250.
Oh lawdy am I having trouble finding parts without paying a million dollars.
Namely Disks, they are chasing $400 ++ AUD for cheap Chinese ones.
Also is there a company that stocks aftermarket chambers / cans for the 16 ?
Thanks in Advance Chaps !
Wed May 06, 2015 12:18 pm » Post: #2 » Download Post
Hello "jumpjuly88", and welcome to NSR-WORLD.
I'm afraid you're fighting a bit of an uphill battle, with an MC16, for new/upgrade parts, however there are ways around it.
For discs, the only decent [new] alternative is EBC, but you are looking at around AU$700 (UK£370) for a set! However, you could fit an MC18/21 front-end.
There are a couple of issues with that, but nothing major. And with that upgrade you have larger 276mm discs, 4-pot calipers, and the option to fit forks adjustable for both pre-load and rebound.
As for expansion chambers, again limited options. Depending on your requirements, I would say modify a set of 1988 R2J chambers. They will take a little fiddling with the mounts, and the silencers will also locate differently, but the MC16 and 1988 MC18 lowers are for all intent and purposes the same, so the pipes should tuck in nicely. The stock MC18 R2J pipes are also very good, performance-wise, even if a little heavy.
Setup with MC18 pipes may be a bit fiddly, so expect a little dyno work.
