reed valve
kukkos
reed valve
Fri Jan 30, 2015 11:56 pm » Post: #1 » Download Post
Hello, I have assembly my reed valve (mc28 sp) with new hrc reed and stuffer + spacer (hrc spec)
Help question :
the specer only (not stopper )will increase the performance or not ?'
Simply I can use it or not Question
I'm sorry bat I want set me in the right direction..
Alessandro Cucco
via Brigate Partigiane 43c
54033 Carrara (MS) Italy
Sat Jan 31, 2015 3:02 pm » Post: #2 » Download Post
I wouldn't advise using only the spacer. Without the stopper, the reeds are likely to fracture and break prematurely.
kukkos
Reed Valve
Sat Jan 31, 2015 3:42 pm » Post: #3 » Download Post
Ok Andy :
I will insert the stopper, I don't understand if the spacer is inserted above or below Question
Or remove it.... Rolling Eyes
Thank you Again
Alessandro
Alessandro Cucco
Sat Jan 31, 2015 3:57 pm » Post: #4 » Download Post
Reed cage >> reed >> spacer >> stopper.... screws! Wink
