i remember andy u said the oil light also was a warning light and mine is showing not. just bought the bike have not started it but it all looks fine but the oil light is on and the oil tank is full. when i turn the kill switch off the light goes off. is this surpossed to happen but comes on as soon as kill is set to on?
the bike has a wire splice and a variable resisor to control the pgm map it runs thought it was a very cleaver idea for racer so u can choose to run 1,2or 3 gear map depending on track? _________________ 94 mc28 SE
Yes that's how it's suppose to work. Once you start it, it should go off. Otherwise you wouldn't know if the oil warning light was functioning or not. _________________ Jerry Lai
NSR250 [MC21SP]
