MC21 rotor upgrade?
scb67
1981 Yamaha RD350LC
MC21 rotor upgrade?
Tue Jan 06, 2015 2:56 am » Post: #1 » Download Post
Does anyone know if there is a front brake rotor with a diameter of 310 or 320 mm from another bike that's bolts up to a stock MC21 hub?
"If your not first, your last!" Ricky Bobby
Tue Jan 06, 2015 2:04 pm » Post: #2 » Download Post
If you really need bigger discs, in my opinion you would be better off going for 296mm, as you will find a lot of original Honda discs that bolt straight up to the NSR wheel, have the correct swept area, and the correct offset.
scb67
1981 Yamaha RD350LC
Tue Jan 06, 2015 4:54 pm » Post: #3 » Download Post
Hi Andy,sorry, I should have explained my request. I looking at doing a fork upgrade and the Forks are setup for a 310mm rotor. Any ideas on what might fit?
Tue Jan 06, 2015 6:13 pm » Post: #4 » Download Post
ISR make a 320mm disc that may work.
yakama
Tue Jan 06, 2015 8:42 pm » Post: #5 » Download Post
Stealth do them, think they will also do new larger rotors for your oem inners:
http://www.stealthproducts.co.uk/
Pinkee
Thu Jan 15, 2015 11:29 pm » Post: #6 » Download Post
the nsr takes the same rim as the cbr250rr, which has the same stud pattern as the cbr900, vtr1000f, and a few others. I have those disks on mine but from memory I think they are 290mm
Thu Jan 15, 2015 11:54 pm » Post: #7 » Download Post
297mm Wink
scb67
1981 Yamaha RD350LC
Fri Jan 16, 2015 2:32 am » Post: #8 » Download Post
Thanks guys....looks like he ISR rotors that Andy mentioned would be my best bet! Thanks for all the advise.
yakama
Sat Jan 17, 2015 12:28 am » Post: #9 » Download Post
Rc30 should fit and is 310 I think
