MC21 pgm3
sami1
MC21 pgm3
Mon Dec 15, 2014 12:15 am » Post: #1 » Download Post
Hi guys, does anyone know where you could have a pgm 3 tested or repaired in the uk?
eyrey1
Mon Dec 15, 2014 2:35 am » Post: #2 » Download Post
whats the bike doing ?
only one ii know of that can do them is 2 stroke race lab
he has mended a lot
but he is in greece
sami1
Mon Dec 15, 2014 2:36 pm » Post: #3 » Download Post
I bought the bike knowing the pgm III was damaged. The back cover was burnt in a small area and it doesnt operate the RC valves. I understand the valves should open and close at certain revs. Any info would be much appreciated.
rhyshrc
Mon Dec 15, 2014 3:06 pm » Post: #4 » Download Post
Hi you can send to greece for 20 pounds via UPS
sami1
Tue Dec 16, 2014 7:05 am » Post: #5 » Download Post
Any one know of a pgm III for sale in UK?
Tue Dec 16, 2014 7:50 am » Post: #6 » Download Post
Try this chap, i think he has one, 07941524339, ask for Alan. Good luck.
sami1
Tue Dec 16, 2014 10:25 am » Post: #7 » Download Post
thanks for that although he recently sold it Sad
sami1
Fri Dec 19, 2014 10:27 pm » Post: #8 » Download Post
Hi guys, what reasons would blow a pgm 3 if the power valves dont have carbon build up or over tightening of the cables? what should I check?
bandit_7
Sat Dec 20, 2014 12:01 am » Post: #9 » Download Post
Sometimes I guess they just fail. My RC valves are spotless and after letting my bike sit for extended periods as I was working away they just stopped working. Sent My PGM to Nick at 2 Stroke Racelab and problem solved. (With the RC valve anyway)...
sami1
MC21 RC servo
Tue Dec 30, 2014 4:58 pm » Post: #10 » Download Post
Could someone please explain how the servo should move at different revs on the MC21?
Just souced a pgm III from Japan and still no movement. Opened the back cover and no sign of damage or charing. Any info would be much appreciated.
mellorp
Banned
Tue Dec 30, 2014 5:15 pm » Post: #11 » Download Post
RC Valve adjustment about 3/4 way down the page
Not sure if it would work, but when you fit the RC valve into the barrel mark the position on the actuator wheel when the RC valve is 2mm recessed. You can then tell where the RC valve is without removing the exhausts.
