ONLY RUNNING ON 1 CYLIDER !
lossa
Sat Jun 25, 2005 11:16 am » Post: #1 » Download Post
hi i need HELP.
i have a mc18 which has started oiling up the front plug.it happens @ any time,i have replaced the coil, still the same.Has any 1 come across this before?.A compression test has been mentioned and the oil injectors as well
does any 1 have any other ideas Smile
the motor has supposidly been rebuilt, new pistons, rings, re-nikkled barrels,bearings and new gaskets.
please im open to all ideas Smile
Jim
Sat Jun 25, 2005 2:42 pm » Post: #2 » Download Post
a long shot but make sure the connection at the coil is clean and tight. I drove myself crazy replacing coils periodically before I finally discovered the real problem was the female connectors from the wiring harness. A clue is if there is any evidence of arcing on the blades of the coil. Knock wood, bike has run great ever since (shite, no wood around, will my head do? now I've done it!).
Good luck and let us know.
-Jim
'93 MC21
cgallant
2001 Honda RS250
Sat Jun 25, 2005 3:54 pm » Post: #3 » Download Post
Lossa,
Is the plug that is getting fouled getting spark> Just cause it's got a new coil on it doesn't mean it's getting spark.
THanks
Charles Gallant
fstnsr
Sat Jun 25, 2005 11:18 pm » Post: #4 » Download Post
check **** gaskets as i had a problem of coolant leaking into the cylender. it was only in tiny amount and was making the plug wet so it didnt spark
94 mc28 SE
invigiator
Sun Jun 26, 2005 12:33 pm » Post: #5 » Download Post
Check for a spark by taking out the plug and grounding the outside (body) to the bike and kicking it over.
MC28 SE -sold-
