front cylinder not idling
krull
Tue Jun 17, 2014 10:14 pm » Post: #1 » Download Post
Hi everyone.
I'm new to the nsr250 mc28 world.
I have read alot of the posts you guys have kindly provided.
I have one question as you can see from the title. I have rebuilt a 1994 nsr250 mc28 the bike will start fine and seems to rev fine but when I let go of the throttle the front cylinder stops firing and smoke roles out of the exhaust when it drop below 3k. My compression is 140-150. If anyone would be kind in shed some light on this would be greatly appreciated.
thanks
rhyshrc
Wed Jun 18, 2014 8:39 am » Post: #2 » Download Post
Having a similar issue.
Have you rebuilt the engine already?
Any more info on background and what you have tried already?
krull
Wed Jun 18, 2014 11:14 am » Post: #3 » Download Post
Hi
Yes the engine was rebuilt and here is a run down of what I have tried.
new spark plugs
new coil
new voltage reg
cleaned carbs
checked connections for arking all clean.
as far as I know there is no wire splice when I got the harnes it had the ground wire of the front lights all soldiered together so I removed it and put it back to original configuration.
When I rev it it fires but then I shut it off and pull the plug from the front it is wet.
Not sure if this is anything but I noticed the ground wire for the thermostat was off but when I connected it the lcd started flashing 135° so I disconnected it.
Alzazorq
Wed Jun 18, 2014 11:32 am » Post: #4 » Download Post
Hi Krull/Rhyshrc,
Check your carb slides that both the left and right slide is opening the same. If not adjust with the screw located between the two carbs.
Also check slow/idle jets as these might be blocked. Once the main jet gets closed by the needle then it runs on the idle jet, if that is blocked then one cylinder will die.
Also check float levels.
Cheers,
Mario
krull
Wed Jun 18, 2014 11:41 am » Post: #5 » Download Post
Thanks Mario
Both the sliders are operating ok.
I will check the slow jet and get back to you thanks again
Alzazorq
Wed Jun 18, 2014 11:50 am » Post: #6 » Download Post
Oh and also check that both air screw passages are clean and both air screws are set.
Cheers,
M
krull
Wed Jun 18, 2014 11:53 am » Post: #7 » Download Post
okay shall do
rhyshrc
Wed Jun 18, 2014 1:37 pm » Post: #8 » Download Post
Did you have this issue before the engine rebuild?
krull
Wed Jun 18, 2014 2:49 pm » Post: #9 » Download Post
no the bike ran fine.
krull
Wed Jun 18, 2014 2:49 pm » Post: #10 » Download Post
Alzazorq
Thu Jun 19, 2014 6:36 am » Post: #11 » Download Post
Also check :
Battery
Charging system
Maybe when the bike idles it does not generate enough power.
Cheers,
M
krull
Thu Jun 19, 2014 12:14 pm » Post: #12 » Download Post
Hi guys
So I checked the carb for blockages and they were all clear.
one kick it started and continued to run the same.
thanks alzazorq
ill check it. what is the value or voltage I'm looking for on the charging system
Alzazorq
Thu Jun 19, 2014 12:43 pm » Post: #13 » Download Post
13.8-14.2VDC over the battery terminals at +-3000rpm. (Just adjust your idel screw so that the bike idles at 3000)
Cheers,
M
rhyshrc
Thu Jun 19, 2014 3:25 pm » Post: #14 » Download Post
Very interested in this thread, tried everything and cant fix it, rebuilding the engine now but interested to see what the outcome the OP has.
krull
Sat Jun 21, 2014 12:13 am » Post: #15 » Download Post
hey guys
thanks for all the help.
so I check the voltage at the terminals and I am getting 14.+\-
still spuratic fire at idle.
you guys rock.
any other suggestions
does anyone know what a flashing temp number 134 means I found my ground to the thermostat off so I connected it and it started to flash 134. so I disconnected it. it still tels the temp correctly
