MC28 Engine to replace MC21.
das134
Tue Jan 07, 2014 5:16 am » Post: #1 » Download Post
Hi guys,
I'm aware this has probably been discussed, but for the life of me I can't seem to find solid info.
I'm looking to put another engine into my MC21 while I get the blown one rebuilt. However it is an MC28 model. I'm aware that the engines are basically the same, but are there any bits that are different between the two?
I.e. do I have to swap the flywheel, change the ignition timing etc?
Keen to get any advice to help maximise the setup.
On that note, does anyone know where I would find a bottom end gasket/seal kit nowadays? Tyga don't seem to stock them anymore.
Tue Jan 07, 2014 7:30 am » Post: #2 » Download Post
Your correct with a different flywheel, but main difference is the MC28 had an extra oil way from the 2 stroke oil pump (although the last year of MC21 had this too) to feed one of the main bearings directly. Can't remember which one exactly.
More minor changes are the generator has a shorter wire to plug it into the loom and the internal gearbox ratios are slightly different.
das134
Tue Jan 07, 2014 8:19 am » Post: #3 » Download Post
racer38 wrote:Your correct with a different flywheel, but main difference is the MC28 had an extra oil way from the 2 stroke oil pump (although the last year of MC21 had this too) to feed one of the main bearings directly. Can't remember which one exactly.
Gotcha, I assume this will be irrelevant if running premix? Or is it advisable to stick with the pump on the later models?
Other than that is it simply a case of switching the flywheels and swapping them over?
Neal
Tue Jan 07, 2014 9:59 am » Post: #4 » Download Post
What's the main purpose for the bike ? Track ? If so then swap the gearbox too , everything will slot straight in .
das134
Tue Jan 07, 2014 10:27 am » Post: #5 » Download Post
Neal wrote:What's the main purpose for the bike ? Track ? If so then swap the gearbox too , everything will slot straight in .
Yeah it's a race bike. Are the 28 ratios no good or something? Not something that can be tuned out with sprocket choice?
Neal
Tue Jan 07, 2014 12:16 pm » Post: #6 » Download Post
The gap between the upper gears is greater , the recommended mod is to run the 21 box .
NSR300
Neal
Tue Jan 07, 2014 12:20 pm » Post: #7 » Download Post
If you access to other gearboxes , you can choose other gears to make a box that suits your track and tune , read up on the gear ratios and you will see some interesting info .
das134
Tue Jan 07, 2014 5:51 pm » Post: #8 » Download Post
Neal wrote:If you access to other gearboxes , you can choose other gears to make a box that suits your track and tune , read up on the gear ratios and you will see some interesting info .
Thanks Neal, I'll have a read up on the subject. Is there anything else I should be considering?
Neal
Tue Jan 07, 2014 9:58 pm » Post: #9 » Download Post
Can you get the mc28 carbs ? They are bigger and could give you more vroom vroom .
das134
Wed Jan 08, 2014 6:04 pm » Post: #10 » Download Post
Neal wrote:Can you get the mc28 carbs ? They are bigger and could give you more vroom vroom .
Unfortunately not, but I have a few sets of M21 carbs so would be hard to justify another set!
Neal
Wed Jan 08, 2014 9:41 pm » Post: #11 » Download Post
Bore them out
das134
Thu Jan 09, 2014 5:05 am » Post: #12 » Download Post
Have you done it? To what size and what difference did you find?
Neal
Thu Jan 09, 2014 11:01 am » Post: #13 » Download Post
Yes I had it done a few years ago ' I think they got 1-1.5mm out of them , on our dodgy dyno we saw an improvement in the mid range right to the top but I think it levelled out on top to similar hp as the stock ones . Jetting went up a few sizes too . If you send me your email I can try look for the printout
