mc28 sp rear suspension
Tadpole
Mon Jun 10, 2013 7:54 am » Post: #1 » Download Post
Was out on a Sunday morning blast yesterday, and the rear suspension bottomed out on few occasions. Wondered if the rear shock is in need of an overhaul..
Has anyone here had their OEM shock sent away for a service? If so how did it feel after, and who would you recommend to use?
I'd like to keep the standard shock to keep the bike looking as original if possible
Graham
stefanos-MC28
Mon Jun 10, 2013 12:21 pm » Post: #2 » Download Post
Hi Graham
I did a service on my rear shock before a week.
I cleaned it ,changed the oil and reload it with new nitrogen.
The way to reload it is to make a hole and put a valve.
The valve has the same diameter with these on the tires.
Here in Greece we have at some gas stations nitrogen for the tires.So i did the job at a gas station.
For beginning i put 35psi but i can load it up to 60psi if it needs.
So i will leave it for now with 35 and see in the future if it needs more or less pressure.
The way to reload it is to make a hole and put a gas valve.
I-factory in Japan sells a kit with a valve for this job.
Owner of : Honda NSR250 MC28 95sp colours / Honda NSR250 MC18 R6K SP / Honda RS250 NF5 89 in boxes Sad / Honda C50 12V cub / Honda C50 12V super cub Japanese version /Yamaha XT600 89 benetton
Wed Jun 19, 2013 8:31 pm » Post: #3 » Download Post
Most of ours go to K-Tech. Good service and they will replate all the steel steel parts in clear zink if you ask them.
Tadpole
Wed Jun 19, 2013 9:39 pm » Post: #4 » Download Post
Thanks for that Stephen.. I'll give K-Tech a shout..
Do you have much done to them when you send them?
Like tell them your weight and if it's track or road? So they put new spring on etc
Or leave it in standard form?
nigel
Sun Jun 23, 2013 9:50 am » Post: #5 » Download Post
mct also do good work
good service and quick turn round
http://www.mctsuspension.com/
Half the strokes, twice the fun
mighty max
Sun Jun 23, 2013 4:22 pm » Post: #6 » Download Post
Do i-factory deal outside Japan?
TuckerBag
Sun Jun 23, 2013 9:14 pm » Post: #7 » Download Post
Excellent post Stefanos !
Thank you.
boostjunkie
Sat Jul 27, 2013 4:36 pm » Post: #8 » Download Post
I have one of those from I- factory , didn't realise it was a valve ...
