Finished Project Not Running Right MC21
joeys boy
Sun Apr 28, 2013 8:54 pm » Post: #1 » Download Post
Hi all i bought my MC21 about 18 months ago and have now finished it Very Happy
Yesterday i took it for its MOT passed no problems anyway i just took it easy after having a full engine rebuild but on the way home i thought id open it up alittle but it has no midrange just flat but when its gets into the higher revs it takes off pulling great through all the gears if i keep the rev high but if i let the revs go down it has no pull seems to be bogging down Sad
When i bought the bike it had nikkon gp style pipes fitted, drilled air box and M Max box fitted. I have kept the same modifacations but changes the pipes to Dog Fighters.
Tonight after reading the jetting infomation on the site i decided to take the carbs to bits only to discover the plastic juntion part (photo) to have broken whould this cause a problem?? anyway i carried on and removed the carbs to see what size jets are fitted but the seem to be standard 128# i would have thought having these modifactions it would have had larger main jets fitted but if that was the case my theory of too much fuel and getting bgged down would be right out of the window!
Any help in the right direction would be greatly apperciated Wink
Thanks Simon
Sun Apr 28, 2013 9:16 pm » Post: #2 » Download Post
Admin: No specific jetting discussion in the public forums please, as per the forum rules.
Any replies quoting jet numbers will be deleted.
joeys boy
Sun Apr 28, 2013 9:41 pm » Post: #3 » Download Post
Andy wrote:Admin: No specific jetting discussion in the public forums please, as per the forum rules.
Were do I discuss these issues?
cgallant
2001 Honda RS250
Sun Apr 28, 2013 9:54 pm » Post: #4 » Download Post
There is a section in the subscribers members are for specific jetting questions (Under the Racing Section, there is a "Setup" section, ask in there).
joeys boy
Sun Apr 28, 2013 10:17 pm » Post: #5 » Download Post
cgallant wrote:There is a section in the subscribers members are for specific jetting questions (Under the Racing Section, there is a "Setup" section, ask in there).
Unable to access that part of the forum?
greggo
Mon Apr 29, 2013 12:30 am » Post: #6 » Download Post
Haven't experienced it myself but I would expect a check of the powervalve operation/RC servo and adjustment would be in order as well?
After you fix/replace the broken bit.
When you do get to discussing the jetting, make sure to check needle height, slow jet, etc and list ALL the sizes/positions.
Midrange is not generally main jet.
Andy has a handy tuning guide buried on the site somewhere which will help no end in establishing if there is something way off in the carb set up.
Mon Apr 29, 2013 1:41 am » Post: #7 » Download Post
Jet chart.
cgallant
2001 Honda RS250
Mon Apr 29, 2013 5:49 pm » Post: #8 » Download Post
Have you fixed the "t" joint? At this point, changing jetting isn't going to do you any good until you get that part replaced.
Also, there is a Jha setup manual for a modified NSR. Would be a good starting point. But as always, specific jetting recommendations is nearly impossible to provide on an internet forum without risk. There are plenty of "guides" on what jets do what, who to tune a 2-stroke based on conditions, setup, etc.. Andy pointed to the jetting chart that addresses what each jet does what. Look for the Jha setup manual to see what they recommend based on their setup.
HRC has some good publications for jetting on an RS250 (jetting is jetting for the most part, so that guide will help you with what to look for and what to do for your specific needs).
mellorp
Banned
Mon Apr 29, 2013 6:32 pm » Post: #9 » Download Post
Me neither ? Couldn't find any links to click ;-(
MC21R ; MC21SP , plus some other none Honda 2t's
cgallant
2001 Honda RS250
Mon Apr 29, 2013 8:50 pm » Post: #10 » Download Post
Here is the link to the "Setup Information" forum in the subscribing members area:
Setup Information
This is in the Supporting Members Forum, Racing, Setup Information forum.
Charles Gallant
mellorp
Banned
Fri May 03, 2013 6:28 am » Post: #11 » Download Post
Thanx Charles - I was looking on the Racing link not the racing Forum
Wink
