Pipe
Bonneville
Pipe
Thu Mar 07, 2013 2:52 pm » Post: #1 » Download Post
Hello,
Can someone tell me what connects to the small pipe stub (comes out of upper crankcase) that sits between the upper cylinder and carb flange on an MC21? Can't see anything on the hose routing diagrams or in the manual.
Alzazorq
Thu Mar 07, 2013 3:41 pm » Post: #2 » Download Post
That's only a breather, so normally a rubber pipe with a 90 degree bend in it so it runs between and under the carbs to the back of the engine, downwards and then exits at the right just aft the fairing, close to the rear belly mounting point.
Normally there's a wire bracket there which holds a few pipes together. If that's not there anymore you may simply have it exit at the bottom somewhere where it does not touch the exhausts, or like on some race bikes have a short one which stops at the back of the carbs.
Mario
Bonneville
Thu Mar 07, 2013 4:35 pm » Post: #3 » Download Post
Brilliant, thanks. There was nothing on mine...
Thu Mar 07, 2013 9:02 pm » Post: #4 » Download Post
You can use the Online Parts Manual to answer things like this, possibly saving you time if no-one's around to answer!
The answer is on page "Crankcase E16" in the MC21 section, and if you look it up, you will not only see an image like this...
...but you will also see the part number to order as a replacement!
