mc21 will not red line ?
marcus127
Thu Feb 21, 2013 4:42 pm » Post: #1 » Download Post
hi wanted to pick your brains my mc21 will stop reving out 500rpm before the redline 11.500rpm and it starts dropping off at 10.500 ish what do you think thank you
mellorp
Banned
Thu Feb 21, 2013 5:43 pm » Post: #2 » Download Post
Is it the same in every gear ?
marcus127
Thu Feb 21, 2013 6:16 pm » Post: #3 » Download Post
Hi yes it is it has short cans on it but standard with standard carb setting
mellorp
Banned
Thu Feb 21, 2013 7:44 pm » Post: #4 » Download Post
And the wire splice ?
marcus127
Thu Feb 21, 2013 7:47 pm » Post: #5 » Download Post
Done
mellorp
Banned
Thu Feb 21, 2013 9:29 pm » Post: #6 » Download Post
I'm sure those with more experience than me would know more, but if it's leaning off at the top end i.e. starving itself of fuel, then it will stop revving out. It might also be the exhausts are a bit coked up. Start with the cheap stuff to check before throwing money at the problem. Will it rev out in neutral or is it under load when it stops ?
Think, Consumables fail/wear/get blocked.
IMO I'd go
Check jets and needles std settings
New plugs, maybe plug caps
Plug Chop - will tell you whats going on
Adjust the jetting accordingly or come back and ask again
HTH
TuckerBag
Fri Feb 22, 2013 1:57 am » Post: #7 » Download Post
Is this a new problem or has it always been like this?
I have never come across this problem but I guess it could be due to any number of things?
I will just assume that the PGM is working well and the power valves are set properly, although you may want to check these.
Blown base gasket or head gasket
Crank centre seal
Check compression is approx 140 psi on both cylinders
Check airbox and filter flow air freely
Check reeds
Check pipes flow air freely
Check that fuel flows freely into the carbs from the tank and that the tank breather works.
Check that the flywheel spins true and cannot move (up/down/forward/back) due to worn main bearings. This may result in sporadic pick-up sensing?
Umm, that's all I can add for now.
TuckerBag
Fri Feb 22, 2013 2:00 am » Post: #8 » Download Post
I don't suppose you just left the choke on? Razz
NSR-lizard
Fri Feb 22, 2013 5:11 am » Post: #9 » Download Post
Badly adjusted RC Valves can easily knock off 500rpm.
Vampire?
mellorp
Banned
Fri Feb 22, 2013 8:06 am » Post: #10 » Download Post
NSR Lizard - Love the strapline
marcus127
Fri Feb 22, 2013 4:56 pm » Post: #11 » Download Post
Ok thanks for the help guys I think it's the power valves when I rev the bike and I see them open I turned it off with the key look at them and the valve is closed in both barrels and when it's ticking over they are open?
Alzazorq
Sat Feb 23, 2013 8:14 am » Post: #12 » Download Post
Unplug the power valve servo, then rotate valves to fully open, go for a ride and see, if the problem whent away then you know it is the pv's.
Neal
Sat Feb 23, 2013 12:55 pm » Post: #13 » Download Post
get a CBR250 if you want to red line it
