mc28 gearbox oil
crillfish
mc28 gearbox oil
Wed Mar 14, 2012 9:25 am » Post: #1 » Download Post
Hi, What grade of oil do i put in my gearbox and how do i gauge the level or should i just drain the old oil and start with fresh oil?
Mark
Wed Mar 14, 2012 9:30 am » Post: #2 » Download Post
0.7L on drain, 0.8L on rebuild.
I've always used Rock Oil light gear oil.
Oil level should just touch the bottom of the dip stick
crillfish
mc28 gearbox
Wed Mar 14, 2012 9:35 am » Post: #3 » Download Post
Thanks for that
crillfish
mc28 gearbox oil
Wed Mar 14, 2012 10:21 am » Post: #4 » Download Post
I have just looked at the filler cap and the dipstick looks a bit stubby as if it has been broken off, its only about 12 mm long
toneless
Wed Mar 14, 2012 11:56 am » Post: #5 » Download Post
Castrol R40 for dry clutches,
Motul Transoil for both wet/dry clutch.
The stubby dipstick sounds fine as long as you have a dry clutch.
2t-racelab.com
Neal
Wed Mar 14, 2012 5:20 pm » Post: #6 » Download Post
And make sure the bike is level and upright
Wed Mar 14, 2012 5:46 pm » Post: #7 » Download Post
Its the same stubby dipstick on wet and dry clutches. It does look like it's broken though.
crillfish
mc28 gearbox oil
Wed Mar 14, 2012 10:35 pm » Post: #8 » Download Post
Thanks all
Hobbit210
Thu Mar 15, 2012 8:40 am » Post: #9 » Download Post
2Tracelab wrote:Castrol R40 for dry clutches,
R40 for a gearbox Confused ????
Thu Mar 15, 2012 9:09 am » Post: #10 » Download Post
R40 or R30 use to be used quite a bit in gear boxes.
