Can someone please help me identify what bike this Magtek rim is off?
I bought it for an RVF400 build and upon going to fit the discs realised they don't fit over the hub?
Upon closer inspection i realised that wasn't my only problem, the width between the two disc mounts is too narrow also.
Uploaded with ImageShack.us
This pic shows the side that still has the curved outer edge of the bearing housing same as the MC21 rims.
This pic shows the other side, which has a different shaped hub with a square finish and two small cutouts, which I am guessing are from a bike with speedo cable off the front wheel?
This is the measurement between front disc mounting points.
And finally i took this one to illustrate where the spokes blend into the hub, compared to the MC21/28 which have about a 20mm wider hub.
Any info is much appreciated.
Chris.
