  • NSR250 Forums Index ‹ NSR500 Discussion
NSR500V engine
Page 1 of 6  Goto page 1, 2, 3, 4, 5, 6  Next Download Topic
NSR500V engine
Sat Feb 25, 2012 11:30 pm » Post: #1 » Download Post
Not many pictures of NSR500 or 500V engine parts on the internet so here are some from my rebuild. I'll add more as I dig bits out.
2001 spec engine with revised crankcases, uprated gear box, clutch and clutch cover as well as nitrided output shaft collar. Det rings in both head and barrel. Magnesium water pump, clutch cover and exhaust manifolds.
Tungsten crank with heavy metal inserts. Ceramic centre bearing.
Sun Feb 26, 2012 3:12 pm » Post: #2 » Download Post
A proper big bore... a real one! Laughing
Sun Feb 26, 2012 3:14 pm » Post: #3 » Download Post
Heads set up up for leaded and unleaded. Some have det rings. 3 types of heads were available, NX6A, B and C. These also different in volume and squish.
t3racing
1990 Honda NSR300 MC21 SP
Mon Feb 27, 2012 12:27 pm » Post: #4 » Download Post
Looks stunning but where the hell do you start when working out how to build it up to run on BP Ultimate Shocked
MC21 300
Aprilia RS250 track bike
Mon Feb 27, 2012 2:25 pm » Post: #5 » Download Post
I would if I was going to use it on the road. I'll be running it on Elf MITS42.
sennidott
Mon Feb 27, 2012 5:33 pm » Post: #6 » Download Post
StephenRC45 wrote:I would if I was going to use it on the road. I'll be running it on Elf MITS42.
Do you know how much that stuff costs???
Can you buy it in anything less than 50 litre drum?
Mon Feb 27, 2012 5:40 pm » Post: #7 » Download Post
Yeah I know! It's going to cost about £400 a day in fuel to do trackdays. Still cheaper than cranks and cylinders though. You can buy it in 25L drums though as well as 50L.
2Smoke
1987 Honda NSR250 MC16
Mon Feb 27, 2012 6:12 pm » Post: #8 » Download Post
Nice view from the workshop Cool
Mon Feb 27, 2012 6:20 pm » Post: #9 » Download Post
That's not the workshop, that's under the house. That's the kitchen!
Mon Feb 27, 2012 6:38 pm » Post: #10 » Download Post
Hmmm... it is sort of the workshop... the second one!
Mon Feb 27, 2012 7:44 pm » Post: #11 » Download Post
3 sizes of primary gear where available. 52t ,53t and 54t.
Mon Feb 27, 2012 8:34 pm » Post: #12 » Download Post
StephenRC45 wrote:Yeah I know! It's going to cost about £400 a day in fuel to do trackdays.
Only if you do the whole day and if you can be as heavy on the throttle as a pro GP rider!
Mon Feb 27, 2012 8:47 pm » Post: #13 » Download Post
I'm going on the same amount of fuel as used in a NSR250. The F3 would use 60L+ a day with ease and not do all the sessions.
Even if it only used as much fuel as a NSR250 that would still be over £200 a day!
Mon Feb 27, 2012 9:34 pm » Post: #14 » Download Post
I'm going on it (with a 26 litre fuel tank) being able to do a 30 lap GP at Donington in the hands of someone very quick.
Mon Feb 27, 2012 9:39 pm » Post: #15 » Download Post
StephenRC45 wrote:I'm going on the same amount of fuel as used in a NSR250. The F3 would use 60L+ a day with ease and not do all the sessions.
Bloody hell! I'm presuming you will be running them on some sort of super special racing fuel?
