CANCELLED Melbourne: Dyno Day March 17
nxrsr20
Mon Feb 13, 2012 7:15 am » Post: #1 » Download Post
cancelled due to insufficient numbers
Alright guys,
I've teed up with Megacycle in Keysborough to do $40 dyno day. It'll be straight power runs (no tuning) with a print out. We need a minimum of 8 people to get this going.
I'll confirm a start time closer to the date, payment will be prior to dyno day. I've mixed this up with a few other 4T riders so it won't be an outright 2T day.
Who's interested?
Lane
Mon Feb 13, 2012 7:44 am » Post: #2 » Download Post
I saw this on the RGV forums as well, be keen to see some of the results of the variants of the 2 models on the same dyno, same day etc.
greggo
Mon Feb 13, 2012 8:28 am » Post: #3 » Download Post
Unlikely I will be run in by this time, so you'll have to say hi to fat guts for me.
nxrsr20
Mon Feb 13, 2012 8:50 am » Post: #4 » Download Post
@greggo You know Mr Megacycle? Smile
@Lane, I won't be taking my NSR with me, it's in pieces, I'll work on a couple of NSR mates to take theirs, see if any RGVers go to it.
Mon Feb 13, 2012 9:35 am » Post: #5 » Download Post
greggo wrote:
Unlikely I will be run in by this time...
Shocked How long does it take you to run an NSR in? Confused
greggo
Mon Feb 13, 2012 8:02 pm » Post: #6 » Download Post
unfortunately as long as it takes to find a track day, or race practice that co-ordinates with my friends not having birthdays or weddings.
Now I look at the calendar it better be done by March 18, that's interclub racing at Phillip Island!
I know Ken, raced 400's for 4 years
nxrsr20
Mon Feb 13, 2012 9:31 pm » Post: #7 » Download Post
you know the engine run in procedure for the NSR is 3 heat cycles?
greggo
Mon Feb 13, 2012 10:30 pm » Post: #8 » Download Post
Then what is all the palava I read about 15 minute sessions up to X rpm?!
Seriously 3 heat cycles up to 70 degrees then shut down?
nxrsr20
Tue Feb 14, 2012 1:52 am » Post: #9 » Download Post
http://www.nsr-world.com/workshop/rebuild/rebuild-5.php
ride like Honda intended Smile
Tue Feb 14, 2012 5:51 am » Post: #10 » Download Post
We built my old motor (complete with rebuilt crank), filled the system with coolant, ran it on the stand to operating temp, checked the coolant level, rode it 4 miles to the dyno, and it made 66-and-a-bit.
We slung some test pipes on it, and it made almost 68hp (no jetting changes). We put the Ethos pipes back on and it made 66-and-a-bit again, and then Steve caned the living daylights out of it, with an evil grin on his face Dick Dastardly would've been proud of!
2 years later, after a couple sets of rings, a set of pistons, and a good few thousand hard road miles, and it was still making 66-and-a-bit. (Back then we were doing a lot of miles too, including a fast 200 mile "TT" round the whole county every few weeks!)
Apart from scuffing teflon coated rings into almost rock hard nikasil bores, what is there to run in? You could bed the rings in on a stand if you really want to!
I bet 50p that if you measured everything up as new, did a whole track day, and then took the motor apart, the wear would be immeasurable to anyone but a rocket scientist, and you couldn't visually see any difference! If the jetting was bang on, you wouldn't even see a mark on the piston crown!
NSR's aren't bore-strokes... there are no shells to bed in, no oil control rings to bed in, no valve trains to bed in and adjust. People put far too much emphasis on "running in" a modern 2-stroke with nickel bores and teflon coated components! If it utilised steel liners, and crap old 70's/80's pistons & rings, then it would be a different matter. Wink
BUT... If you are more comfortable running several sessions at xx, then xxx, then xxxx rpm/mph/load, then go with it.
Note: Steve's 75hp F-III had brand new rings in at Donington. It did two sighting laps behind the instructor in the first session (as everyone did), and then it was ragged senseless all day... by several people.
greggo
Tue Feb 14, 2012 9:29 am » Post: #11 » Download Post
I do like the sound of ragged senseless....
nxrsr20
Tue Feb 14, 2012 6:41 pm » Post: #12 » Download Post
so you gonna turn up to the dyno day then? Razz
adz35
1993 Honda NSR250 MC21
Wed Feb 15, 2012 9:01 am » Post: #13 » Download Post
I would be interested if im not busy.
NSR250 MC21 SE
RGV250 VJ22 SP
nxrsr20
Tue Feb 21, 2012 7:37 pm » Post: #14 » Download Post
Alright folks, in order to confirm the day, if you are definite I will need payment by Friday March 2.
PM me for payment details.
